Forced Induction Turbo, Supercharger, Methanol, Nitrous |
04-06-2015, 02:34 PM | #1 |
Boosted
Drives: Sideways
AFR mostly rich, erratic at times
Just developed this issue today and being that this is my first turbocharged car I would like to ask for some help diagnosing possibilities.
After some research I've found a broad list of issues it might be:
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
04-06-2015, 03:25 PM | #2 |
Drives: toyota mr2/ Toyota GT86
Hello
I'd check for exhaust leaks before the O2 sensor as if this has been experiencing an exhaust leak then it will have been running very rich as the sensor will see the extra air pulled in as fresh / lean fuelling and be adding fuel to compensate. if thats OK try replacing the 1st O2 sensor |
04-06-2015, 03:34 PM | #3 | |
Boosted
Drives: Sideways
Are you talking mostly about turbine housing exit to exhaust area?
04-06-2015, 03:57 PM | #4 |
yes any leaks upstream of an O2 sensor can pull air in and so give a false rich reading
you say you're running wideband, is the sensor replacing the factory wideband or is it additional? also are you on the stock ECU with ECUtek, OFT etc? or on a standalone like Motec? |
04-06-2015, 04:09 PM | #5 | |
Boosted
Drives: Sideways
I use Ecutek.
04-06-2015, 05:05 PM | #6 |
OK if the wideband has replaced the stock item and you're not using any closed loop function in your tune then it won't be effected by any leaks or faulty sensor
from the sound of it though I suspect that you are using closed loop but have changed the sensor gains so it uses the Wide band as the main input |
04-06-2015, 05:13 PM | #7 |
Drives: UK GT86
Have you any catalogs? Might help to see if trims are at play etc?
.: Stealth 86 :.
04-06-2015, 06:17 PM | #8 | ||
Boosted
Drives: Sideways
04-06-2015, 06:21 PM | #9 |
Boosted
Drives: Sideways
Saw some improvement on the drive home for no reason whatsoever. Was running upper 12's and 13 flat AFR for most of the ride in higher gears and part throttle. I didn't go past 8psi either, which I'm not sure if it helped the situation or not. Idles at upper 13's and occasionally 14's now as of getting home.
Sprayed the MAF and several other electrical components completely clean just now too. I suppose I'll update tomorrow but I'm very skeptical that this just randomly "fixed" itself. Unless maybe there was some bad gas or something of the sort. I have some gaskets on the way because I'm about to buy a new turbo anyway (different reason). I'll post more symptoms and/or hopeful good updates as soon as they come. Thanks for the help.
04-07-2015, 09:53 AM | #10 |
Boosted
Drives: Sideways
STILL HAVING ISSUES
But they aren't as bad.
Any ideas? Could this just be a wideband going bad or?
04-07-2015, 10:41 AM | #11 |
NASA SpecE30 Racer
Dude you gotta get an EcuTek cable and get some datalogs to trouble shoot. You still running a D3PE tune right.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
04-07-2015, 10:48 AM | #12 | |
Boosted
Drives: Sideways
I'm literally waiting for the turbo to ship before my flex-fuel upgraded turbo project and now this happens. I just placed an order for a replacement wideband sensor though, I feel like this one has been put through A LOT of crap. It's had oil blasted on it numerous amounts of times before I originally fixed the oil problem. It just seems like a smart move regardless of whether it fixes this problem or not.
04-07-2015, 02:02 PM | #13 |
Boosted
Drives: Sideways
It has to be the AEM wideband sensor. Basically every tells me these things are lucky to last 2 years and I've had it for a bit more than that. Combined with said turbo oil problems above I don't see how the sensor even made it this far.
I also noticed that when the key is ON but engine off the sensor reads mid 11's. Not sure what that means.
04-07-2015, 04:48 PM | #14 |
Drives: UK GT86
Tried a recalibration?
I was told some time ago that the NGK sensor AFX was the best wideband if you're not going professional lab quality. It's not too badly priced either.
.: Stealth 86 :.
Similar Threads | ||||
Cel gas running to rich | anthonyravenfrs | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-15-2014 01:55 AM |
So what would you say is too Lean? Too Rich ? Opinions Pls. | BC-Boy | Software Tuning | 27 | 05-29-2014 10:05 PM |
POST YOUR 1/4 MILE TIMES Quarter mile times | NYCsubaruBRZ | Tracking / Autocross / HPDE / Drifting | 1 | 02-04-2014 06:59 AM |
Running rich | KslayFRZ | Issues | Warranty | Recalls / TSB | 15 | 10-25-2013 11:42 PM |
Rich man's FR-S (WRB BRZ) | Hamza7 | Cleaning and Detailing | 9 | 06-24-2012 11:36 AM |
