08-23-2021, 11:52 AM | #1 |
Drives:
CAN BUS translator
Is there any guy here who can help me to decode the can bus data from oem ?
I need the shift up , shift down data from oe lingo to translate to use in my M1 Car is Auto Also paddle shift + and - command data. Thanks guys |
08-23-2021, 12:37 PM | #2 |
Drives: Some rust bucket
I'm assuming you have some software engineering skills but this project decodes the CAN data. They don't have a specific BRZ/86 file, I would assume it's similar to the existing Subarus.
https://github.com/commaai/opendbc |
08-24-2021, 09:40 AM | #3 | |
Drives:
I will dig into it |
08-26-2021, 01:14 AM | #4 | |
Drives: 2022 GR86
https://github.com/timurrrr/RaceChro...can_db/ft86.md If you find more info on various CAN IDs and data formats, feel free to send a pull request! |
The Following 4 Users Say Thank You to timurrrr For This Useful Post: | pro_turbo (08-27-2021), RedReplicant (10-07-2021), Takumidesh (10-01-2021), whataboutbob (08-26-2021) |
08-27-2021, 09:07 AM | #5 | |
Drives:
10-01-2021, 01:44 PM | #6 | |
Drives: 2013 FR-S, 2015 TC
Can I ask what you are using to talk to the car? I am using a breadboard with mcp2551 and mcp 2515 + arduino mega2560. I get communication and everything but my biggest struggle as it stands is communication speed, any tips?
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY KANSAI DORIFTO |
10-01-2021, 08:39 PM | #7 |
Drives: Scion FRS
I'd recommend an ARM based controller, lot more power. I was recently looking at this combo, but haven't tried it out yet Should be convenient to either connect as serial, or store on the flash card.
10-02-2021, 09:54 AM | #8 |
Yea I think the issue is with using the USB serial on the Arduino, I'm trying today to connect the connections directly to the spi io pins on my rpi 3.
10-04-2021, 01:41 AM | #9 |
Drives: 2022 GR86
The Following User Says Thank You to timurrrr For This Useful Post: | Takumidesh (10-13-2021) |
10-13-2021, 11:56 AM | #10 |
FYI anyone looking into working with can bus should read The Car Hacker's Handbook. it is focused on penetration but it goes in depth on automotive bus protocols.
Similar Threads | ||||
LS3 swapped BRZ with EVERYTHING working - Plug in Canbus Translator | toddy101 | Engine Swaps | 20 | 04-13-2020 11:39 AM |
New Canbus Translator | geraldjust | Engine Swaps | 18 | 04-23-2019 02:57 AM |
