Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
07-28-2017, 09:57 PM | #29 | ||
07-29-2017, 10:25 PM | #30 |
Huge E85 fan!
Drives: 2016 Scion FRS
OP-
Hello, friends! So, my car has been having issues starting lately. I have a push start brz, and sometimes when I try to start the car I hear a single click, and no crank. after trying a few times the car would start. Some days it starts on the first try. Other days, it takes a few tries. Today, it wouldn't start at all, so I took the battery to get tested, and it's still good (less than 6 months old). I then moved on to the alternator. Got it out and took it for testing too. Alternator is also good. Okaaaay... so, my only conclusion now is that the starter is faulty. What do you guys think? Thanks ahead of time for the help! Single click is either starter or battery connection. TANNER said.... As soon as I reset the power (have a battery disconnect switch and never had problems with it or power going off while driving - which would be a bad thing), everything came back to life. Got back in the car, it's like as if I tried to start the car but without the clutch depressed. I'm starting to wonder if there's a relay that's acting up.... OP is Gray Fox, Tanner is the other guy. I'm all confused. Who's fucking car won't start? |
07-29-2017, 10:41 PM | #31 | |||
The Following User Says Thank You to Tcoat For This Useful Post: | guybo (07-30-2017) |
07-31-2017, 08:22 PM | #32 | |
Drives: WRB Limited BRZ
I wanna add that I recently just got a new battery from Autozone, and I also just got my spark plugs replaced, and got a new Key FOB battery. |
07-31-2017, 09:44 PM | #33 |
Huge E85 fan!
starter or battery connection. Start by taking off the battery terminals and cleaning them. Make sure they are very tight (you shouldn't be able to move them by hand at all).
A single hard click is almost always one of these things. |
The Following User Says Thank You to guybo For This Useful Post: | Alltezza (08-01-2017) |
08-01-2017, 05:11 PM | #34 |
I went and checked, everything looks good, I'll see if I can find the thread again but I read somewhere that basically for the push to start car you have to actually wait to get the "green" key lit icon on your dash and then start the car. Something about a safety feature I guess.
I usually just go in and just stomp on the clutch and press the button and bam it starts the car. I'm not sure if that's the reason why but I've been actively waiting to see the damn "green key" icon and then starting my car and I've had no issues today. |
09-10-2017, 12:41 PM | #35 |
Drives: Silver 10 series
So to add to this thread. My daughter has the 2013 series 10 standard trans with 35k miles. She has been having stating issues with the push button start also. We have replaced the battery in the key fobs. I just replaced the main battery as it was tested and bad. I thought that was it, but she told me today that it didn't start again.
She gets in the car, gets the green key icon after pushing in the clutch, then pushes the button, all the lights come on like normal, but the nothing. The engine doesn't even try to turn over. One time she said she heard it click like this post says, but most of the time she just gets nothing. After waiting it out a little bit the car starts fine. I'm assuming the clutch switch is good, because the green key icon comes on when the clutch is pressed in. We know the battery is good. No corrosion clean terminals. Key fob battery good. When I changed out the battery, I did jiggle the wires on the starter to make sure they were on secure. I'm assuming the ground wire is secured on with all the other lights coming on. I saw a YouTube video about something with the steering wheel lock. She has tried shaking the steering wheel to get it to start, but did not work. I guess maybe check the starter relay? Is there anyway to test it or do I just gotta buy a new one? Also I guess I'll have the starter tested. I'll keep plugging away at it, it's just getting frustrating. Any other tips I should try? For me it feels like something is up with that button or sensor to get to the starter. |
09-12-2017, 02:02 PM | #36 |
I think I've narrowed it down to one of the sensors under the clutch pedal. I found this YouTube video and it's the exact same thing her car is doing.
The Following User Says Thank You to FRSFather For This Useful Post: | Cheeky (05-01-2021) |
05-02-2021, 12:10 AM | #37 | |
Drives: 10 Series FRS
This problem has started to plague me the last year. Replaced key fob battery, worked for a bit but then the problem started again in less than a few weeks. Car battery is about 2 yrs old but honestly I doubt it's the problem if sometimes it works fine. No cranking sounds, just nothing at all... I am gonna try to replace the clutch pedal sensor I guess but need the part # or source. |
05-02-2021, 09:57 AM | #38 |
Before you replace, check the position of the switch. Friend had one that had come loose.
The Following User Says Thank You to ls1ac For This Useful Post: | humfrz (05-03-2021) |
05-04-2021, 02:19 PM | #39 |
Thanks, not sure which switch you are referring to, but if it's the clutch sensor switch/module, I checked it and it wasn't loose or anything. Even used my finger to click it myself a few times to see if it was a mechanical failure and it was not.
For me, now I am pretty certain that it is the sensor failing, because I noticed that as long as I pushed the clutch in and the green key light showed up, my car would start up 100% without fail. Whenever I pushed clutch in and green key didn't show up, it would not turn on. |
Similar Threads | ||||
Car doesn't start without fully charged battery. | frsq5 | Issues | Warranty | Recalls / TSB | 6 | 06-09-2017 09:59 PM |
Key battery dies, anyway to start firs manually. | cfee40 | Electronics | Audio | NAV | Infotainment | 11 | 05-21-2017 11:31 AM |
Losing all battery voltage when trying to start car. | armstrom | Issues | Warranty | Recalls / TSB | 14 | 11-18-2016 03:15 AM |
Car WON'T START dead battery? | AnthonyArcaro | Issues | Warranty | Recalls / TSB | 17 | 01-19-2016 12:00 AM |
Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 06:06 PM |
