Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
12-27-2019, 03:29 PM | #29 |
Drives: 2012 Toyota 86
Well I tried one dealer but they referred me to their special parts order department which im waiting to hear from.
Other Businesses are closed today until Monday. So I wanted to try and see if there were stores online that had them in the interim. Oh I'm in Jamaica by the way . Sent from my SM-N975U1 using Tapatalk |
12-27-2019, 03:46 PM | #30 | |
義理チョコ
https://parts.toyota.com/p/Scion_201...U00300821.html
12-27-2019, 04:20 PM | #31 | |
Thank you very much for the assistance though! Sent from my SM-N975U1 using Tapatalk |
The Following User Says Thank You to Gamace For This Useful Post: | Ultramaroon (11-30-2020) |
11-30-2020, 07:53 AM | #32 |
Drives: Asphalt FR-S
What's the location of this switch? I think I have the same issue.
Sent from my Pixel 4 XL using Tapatalk |
11-30-2020, 01:11 PM | #33 | |
Drives: 2016 BRZ
https://demos.starbase7.net/t3Portal...modelyear=2016 |
The Following User Says Thank You to Joon525 For This Useful Post: | Rican_D (11-30-2020) |
11-30-2020, 01:12 PM | #34 | |
11-30-2020, 02:19 PM | #35 |
Just went under the car. Looks like a bitch to get to. How did you guys do it?
11-30-2020, 02:58 PM | #36 |
Drives: Many
I did it from up above, just reaching back.
It's not super fun. |
The Following 2 Users Say Thank You to e1_griego For This Useful Post: | Rican_D (11-30-2020), Ultramaroon (11-30-2020) |
11-30-2020, 04:28 PM | #37 |
12-01-2020, 07:01 PM | #38 |
07-19-2021, 03:00 PM | #39 |
Drives: BRZ S
Would an extra washer make the button further away? I would assume he grid down the shoulder of the sensor? I am having a similar problem i think. My indicator shows fine but my lights only show if I wiggle the shifter.
07-19-2021, 05:02 PM | #40 |
義理チョコ
I wondered about that too. Didn't want to make it a thing. It might be like the door switches where the circuit is closed upon release. Then adding the washer makes sense. We can check the wiring/circuit diagrams to verify. Look for the manuals in my sig line. I'll study them after work today. The disagreement between reverse indication, and lights would make sense if the indicator latches electronically between reverse and neutral. Then, even a momentary reverse signal would not be cancelled until switching back to neutral.
07-20-2021, 12:27 AM | #41 | |
Drives: BRZ S
07-20-2021, 01:43 AM | #42 | |
義理チョコ
https://gt86stuff.onrender.com/t3Por...017MP03IX.html
Similar Threads | ||||
FR-S / BRZ Reverse/Backup LED Bulbs! See Comparison Photos, Ships Same-Day! | Diode Dynamics | Exterior Parts - Lighting | 72 | 11-30-2021 02:19 PM |
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! | Diode Dynamics | Exterior Parts - Lighting | 192 | 10-04-2017 11:51 AM |
Reverse gear signal on factory HU harness? | Panman | Electronics | Audio | NAV | Infotainment | 2 | 01-24-2014 10:24 PM |
Interior LED + Reverse backup package? | Intake | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-12-2013 11:46 AM |
Radio Signal Issue When shifting into Reverse | ruskymx | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 01-22-2013 09:05 PM |
