Old 08-10-2016, 08:00 PM   #1
Strife
Strife's Avatar
Drives: Hyperblue BRZ
Few questions about rustproofing exposed metal
I'm going to be cutting my fenders in order to add widebody overfenders and I'm concerned about and rusting that may occur by exposing any metal. This is more of a concern in the front as the rear will have the metal shroud folded and sealed over the exposed metal.
Another question, is it possible to fill in the divets of a widebody kit with bodyfiller or another mixture then have that painted over to give it a cleaner look (Cheaper then going molded). Divets/indents as seen here:
Thanks for any help! I really appreciate it
Strife is offline   Reply With Quote
The Following User Says Thank You to Strife For This Useful Post:
Anderzz (08-10-2016)
Old 08-10-2016, 09:25 PM   #2
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
I'd be interested in this as well to winterize the installation spots from my side skirts/lip/diffuser
Anderzz is offline   Reply With Quote
Old 08-10-2016, 09:27 PM   #3
Kiwis
Kiwis's Avatar
Drives: 2016 Blackout BR86
Paint and clearcoat? Or just clearcoat the rivets/screws before using them.
Kiwis is offline   Reply With Quote
The Following User Says Thank You to Kiwis For This Useful Post:
Old 08-10-2016, 09:34 PM   #4
Strife
Strife's Avatar
I'm more worried about the edges of post-cut fenders. Here's a pic so it makes more sense!
Edit: You were probably replying to the guy above, my bad
Old 08-10-2016, 09:37 PM   #5
Kiwis
Kiwis's Avatar
OH! So while this may not be the absolute best way to attack this, B is for Build had a pretty great method as to solving this:
[ame="https://www.youtube.com/watch?v=zx_lArJxCB4&index=6&list=PLHFFREt3OXLHs_BS ce-_WDgj9AWCah8PE"]Plan B BRZ Pt 12 - DIY Install Rocket Bunny Widebody Kit Pt 3 - YouTube[/ame]
There's likely a more professional way, but from a DIY standpoint, this is the best I've seen as of yet.
Strife (08-10-2016)
Old 08-10-2016, 09:45 PM   #6
Strife
Strife's Avatar
Thanks! I should've gone back and watched all of Chris's videos. That solution seems great. Just need to find another material to use instead of sheet metal.
Kiwis (08-10-2016)
Old 08-10-2016, 11:18 PM   #7
Johnny.
Johnny.'s Avatar
Drives: A work in progress.
When I did mine I covered the bare metal with seam sealer. Like I smeared or to make sure everything was covered, then taped everything off and sprayed the edge with like a rubber undercoating spray. I've run into no issues so far.
And I used rivertnuts and bolts to hold the kit onto the car. I covered the rivetnut with silicone when installing them.
Johnny. is offline   Reply With Quote
The Following User Says Thank You to Johnny. For This Useful Post:
Strife (08-10-2016)
Old 08-10-2016, 11:36 PM   #8
Strife
Strife's Avatar
Okay, I was wondering if something like that would work. That seems like the simplest way going about it. Thanks man!
Metal on metal noise at 2500 RPM ssyed Issues | Warranty | Recalls / TSB 2 09-08-2014 04:01 PM
Metal on metal scratching noise front left wheel Ezk1el Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-11-2014 12:00 AM
[Question] How to remove stains from rustproofing i_4got Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 05-01-2013 04:59 AM
Scion Exposed 10.0 / 4-27-13 / 10 AM to 5 PM Dam262a Southeast 16 02-17-2013 10:59 PM
Rustproofing for Winter blackfireball5 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 28 11-12-2012 10:33 PM
