07-17-2014, 08:18 AM | #2059 |
Drives: Scion FR-S
Nice! I see you have the Perrin exhaust. Any other mods? I have full Perrin header back exhaust so I'm trying to get a feel of what mine will sound like when I get it next week.
My build thread:
http://www.ft86club.com/forums/showthread.php?t=63292 |
07-17-2014, 02:54 PM | #2060 | |
Drives: Seibon Style BRZ
Aloha, Ace |
The Following User Says Thank You to teamxplizt For This Useful Post: | hattrickey (07-17-2014) |
07-18-2014, 11:39 AM | #2061 |
Drives: 2013 CBS BRZ
So just to be totally clear, you DO NOT need a tune with these headers? I can run the for the life of the car with the stock tune and not have to worry?
07-18-2014, 01:31 PM | #2062 | |
Drives: asphalt fr-s
But to answer your question, yes, you may run this for the life of the car witout a tune. Your AFR may be slightly on the rich side, which is not a problem in and of itself. Anyone care to talk about risks of running rich?? maybe carbon buildup?? or is it the other way around? Last edited by SCharged; 07-18-2014 at 02:27 PM. |
The Following User Says Thank You to SCharged For This Useful Post: | TONYpepperon1 (07-19-2014) |
07-18-2014, 05:16 PM | #2063 |
Drives: GT86
Had the impression that it was the other way around, a little lean.
With no other mods the header can be run without a tune as per first post. Add other modifications and it becomes more complicated as it is difficult to say anything firm with all the possible combinations... |
07-18-2014, 05:24 PM | #2064 | ||
Noob
Drives: FR-S Mammogram
Too lean - higher risk of pre-detonation (knock) Quote:
I'd have figured it'd be leaner as well.
07-18-2014, 07:40 PM | #2065 | |
Drives: Scion FR-S
The testing and dynos done were done on a stock car with only the header changed in which everything works great. The CEL that this header should not cause after doing our testing is p0420 which is the one relating to the cat itself. If you have a heavily modified car with full exhaust, intake, and etc a tune should be something to look into. You will extract even more power and resolve the lack of fuel in certain driving situations." Based off of this advice, I will be getting a tune.
My build thread:
The Following User Says Thank You to hattrickey For This Useful Post: | Trettiosjuan (07-19-2014) |
07-21-2014, 05:41 AM | #2066 |
Drives: Yes
Ran both OFT Stage 1 and Stage 2 this weekend... it felt less torquey running Stage 2. I ended up flashing back to Stage 1 and it feels better (according to butt dyno).
Header-back exhaust only (catted header, catless FP), stock intake with Perrin tube. Here's a shoddy log on Stage 2 from today... was just testing out the logging feature so not sure if the data's any good. Hopefully someone can interpret it better than I can. http://www.datazap.me/u/chas3wba0/st...g=0&data=1-2-9 Will do a log for Stage 1 this week. What's the best way to log? Cruise for a bit then a WOT run?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post: | kodyo (07-21-2014) |
07-21-2014, 06:09 PM | #2067 | |
Drives: Scion FR-S
I plan to go with OFT if I get a CEL after install. |
07-21-2014, 06:27 PM | #2068 |
Drives: Yes
Did not test with stock map, as I was already running Stage 1 before I installed the header. OFT Stage 1 was a world of difference from stock (smoother idle and revs, more linear power curve) so I would recommend it whether you get a CEL or not.
07-21-2014, 06:41 PM | #2069 | |
Drives: Scion FR-S
If I can find a good price on an OFT, I may go for it. |
07-21-2014, 06:59 PM | #2070 | |
Drives: Yes
I would say the most noticeable things from the header are throttle response, rev-happiness, and SOUND Edit: I take it back. After a few experiments on freeway on-ramps, the car definitely pulls harder up top as well
07-21-2014, 07:01 PM | #2071 |
So elite I'm 1338
Drives: WRB Subaru BRZ
When I installl mine, I'll post the dyno for the new header design. Problem is, I'm not installing til next season. But doesn't look like anyone else is posting dynos for the new ones.
07-21-2014, 07:19 PM | #2072 |
if mine ships this week, I'll have a dyno sheet next week, or the week after.
Tags |
catted uel header, ft86speedfactory header, is my order ready yet? |
Similar Threads | ||||
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 107 | 03-29-2016 10:48 AM |
catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 12:32 PM |
P&l EL catted and coated header. | wootwoot | Engine, Exhaust, Bolt-Ons | 8 | 10-11-2013 12:50 AM |
Catted UEL Header | Cjymiller | Engine, Exhaust, Transmission | 20 | 05-24-2013 12:01 PM |
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 12 | 10-24-2012 10:12 PM |
