Old 04-27-2022, 08:22 AM   #43
Ohio Enthusiast
Drives: 2018 BRZ
Originally Posted by churchx View Post
why it was so hard for whiteline to get it right in past.
I seem to remember Whiteline just sold their WRX offset top hats for the Twins, but the Twins had a greater angle between the top hat and the strut. This was fairly common for the Twins at the beginning, where other Subaru models' aftermarket parts were sold as-is because they kinda fit, but that often ended poorly. Luckily we have plenty of custom made Twin parts now.
Ohio Enthusiast is offline   Reply With Quote
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
marco_mc22 (04-27-2022), wparsons (05-02-2022)
Old 05-02-2022, 03:04 PM   #44
wparsons
wparsons's Avatar
Originally Posted by BlueWhelan View Post
Pulled em off because they weren’t legal in my class, but they held up great! Highly recommended
I still have the set
Originally Posted by 7 skulls View Post
I've had them on since 2020. No problems so far. About 20 000km.
Amazing, thanks guys!
flickr
Old 05-11-2022, 05:44 PM   #45
BRZrkr
Drives: 2017 BRZ PP
Is there a detailed DIY install for these? Does the strut assembly need to come out for install?
BRZrkr is offline   Reply With Quote
Old 05-11-2022, 06:32 PM   #46
7 skulls
Drives: 2014 scion frs
Any of the strut install DIYs here is basically the same. Struts must come out. Subaru recommends new nuts for the 3 on the top hat and the one on top of the strut. Don't turn the strut top nut without holding the shaft. I used a pass through socket and an allen key. I also used new bolts and nuts on the bottom.
7 skulls is offline   Reply With Quote
Pedders top hats and subaru camber bolts... results. 7 skulls Suspension | Chassis | Brakes -- Sponsored by 949 Racing 58 02-01-2021 06:24 PM
Pedders Top Hat w/ Camber & Caster Offset - Anyone with experience? Jamestl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 11-16-2018 04:35 PM
FS: RCE T2 Coilovers w/RCE Camber Plates and MSI Top Hats jprice130 Brakes, Suspension, Chassis 4 09-23-2016 09:36 PM
FS: Robispec rear top hats, OEM front top hats, Scion wheel caps, OEM coin holder MyRx Brakes, Suspension, Chassis 5 10-12-2014 02:14 PM
