Member's Car Journals Car journals by our members. |
07-17-2024, 01:04 PM | #183 |
Drives: None
It's hard to tell in your data there, but the pressure drops I had with my car were all off throttle and immediately recovered upon picking up the throttle. Try toggling on throttle position.
Pretty much every car I've tracked before would drop pressure under this situation, I think worrying about it is mostly a case of fragile FA20 view haha
The Following User Says Thank You to RedReplicant For This Useful Post: | gt5759 (07-24-2024) |
07-17-2024, 02:44 PM | #184 | |
Drives: Fr-s
Yes
It's not that low, lower RPM and no load so...
The Following 2 Users Say Thank You to redlined600 For This Useful Post: | autoracer86 (07-17-2024), gt5759 (07-24-2024) |
09-12-2024, 11:29 AM | #185 |
Drives: Fr-s
Went up to BIR for some Sunday fun. Overall ok, the car was obviously faster than last time I was there (by almost 3 seconds iirc) but the track didn't feel very grippy. In the afternoon was a standing start time attack. There were a bunch of ClubTR cars there to compare to. I got 3rd in my class but definitely felt I left some time on the table, especially in turn 3, for whatever reason I don't do a good job of blending the braking zone into the turn. Honestly, I think I just need to make more events and drive more.
On the last session of the day I came out of turn 3 and had what I thought was a nasty misfire which was getting worse. Not wanting to oil the track, just in case, I pulled off and got the tow of shame. Ecu showed codes for cam sensor so I had hope it was going to be something simple. As I started to investigate I quickly started to realize it was a little more terminal I'm pretty sure that valve is in the wrong place. Modified low compression piston. Right now it's hard to attribute the failure to anything. Oil Pressure looked good, Lambda looked ok, the timing is still on. The engine was of unknown history....it could just be back luck and a valve broke. I'll tear it down eventually to see if there are any more bread crumbs. For now, fingers crossed that the cams and oil pump survived so I can put them on the new motor. I had one more event planned but with upcoming travel, I think it's pretty unlikely I'll make it.
10-04-2024, 03:03 PM | #186 |
Drives: Fr-s
I pulled the cams to see if I could re-use them and found this, the roller fractured and fell off. I don't know if this a cause or result, but kinda crazy either way.
While I can't drive the car I may as well work on it. I pulled about 21 lbs of random crap out. I'm not sure if I ever posted an image of the modified s2000 header. It's not pretty but it works. It's also heavy AF, but probably won't ever crack. It also allows me to run the factory heat shields and didn't require me to clearance the engine bay to fit. I didn't really explain earlier but I chose to stay with the same exhaust design philosophy as the OEM FRS, which is to say, the exhaust is more or less rigidly mounted up to the end of the transmission where there is a flexing donut joint. Kpower chose to use a traditional exhaust hanger at the transmission mounting point (I don't know if they maintain the donut joint but it doesn't look like it) and I have to wonder if this contributes to the exhaust failures people are seeing. I also added a bracket that mounts between the header and adapter plate. I noticed that the stock k24a also incorporates a exhaust manifold brace.
The Following 2 Users Say Thank You to redlined600 For This Useful Post: | RedReplicant (10-08-2024), villainous_frx (10-12-2024) |
Similar Threads | ||||
The Rebirth of an Italian | FlowForm_Wheels | Other Vehicles & General Automotive Discussions | 16 | 06-01-2014 12:46 PM |
Trackday GPS Recommendation | milhouse | Tracking / Autocross / HPDE / Drifting | 12 | 03-24-2014 01:19 PM |
Trackday at ORP | jblmr2 | Northwest | 6 | 02-21-2014 06:30 PM |
2nd trackday in FR-S | icemang17 | Tracking / Autocross / HPDE / Drifting | 4 | 09-24-2012 05:40 PM |
1st trackday in FR-S | icemang17 | Tracking / Autocross / HPDE / Drifting | 10 | 09-01-2012 11:02 PM |
