Clash0901
Old 01-18-2019, 02:00 PM   #85
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Do you have a plan for AC?
Yea, throw it away lol.
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
The Following User Says Thank You to Clash0901 For This Useful Post:
Trust86 (02-19-2019)
Old 01-18-2019, 02:04 PM   #86
Ashikabi
Ashikabi's Avatar
Don't want it or can't use it?
Old 01-18-2019, 02:06 PM   #87
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Don't want it. It shouldn't be too hard but you will need custom made lines.
Old 02-19-2019, 09:01 PM   #88
lilred
Drives: 2013 FRS
IS IT FINISHED!!!!
Randomly came across this post and im interested if you guys finished the build!
lilred is offline   Reply With Quote
Old 02-19-2019, 09:22 PM   #89
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
He said above that he hopes to have it tuned and running in June. That, and his sig says it is in progress.
Old 02-20-2019, 10:03 AM   #90
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I don't remember what page it's on, but I also said i'm taking a break during the winter. Since I don't work on this car at my place (no room), I have to respect my buddy and his garage space/time. So i will be back to work sometime in March on this bad boy. I will then continue with the updates on this thread
Old 02-20-2019, 07:50 PM   #91
lilred
Drives: 2013 FRS
I didn't realize the dates! but good luck and cant wait for it!
Old 05-13-2019, 11:14 AM   #92
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
oof!
The Following 3 Users Say Thank You to Clash0901 For This Useful Post:
boost86 (05-15-2019), DustinS (05-13-2019), Irace86.2.0 (05-13-2019)
Old 05-15-2019, 11:42 AM   #93
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I did all that work (see previous pages on this build thread) to get the heater core lines coming out of the center of the firewall, behind the head, and was still extremely unhappy with it due to tight clearances. So I found a new spot for the heater core lines to run through in the firewall. The spot I found was just below the CMC and I made 2 nice holes as shown below
Then I put some rtv around the holes and shoved in these nice rubber grommets.
Here is the final result with my AN lines coming out of the holes and you can't see but they are attached to the heater core inside the vehicle.
My next task is figuring out how to delete this battery sensor/plug OR moving it all the way to the trunk (which won't be terribly difficult, just annoying and seemingly un-necessary)
Irace86.2.0 (05-20-2019)
Old 05-15-2019, 12:33 PM   #94
Ashikabi
Ashikabi's Avatar
Very nice
Old 05-20-2019, 03:08 PM   #95
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Here are my custom made heater core lines! This took me forever to think of. I am running 5/8 to 1/2" adapters and going from the oem 5/8 hard pipe to a -8AN hose (close to 1/2").
Old 07-01-2019, 10:50 AM   #96
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I've made a lot of progress on the car in the last month. I don't have photos since some of the stuff is miniscule like adding the CX Racing coolant hoses, wiring in the FAL fans to the oem harness, making the wiring harness for the dual fuel pumps and wiring those in, assembling my PTFE fuel lines, installing and assembly my oil catch can, and a few other small details. Figuring out where everything is going to mount and "go" so it all flows and doesn't obstruct something else has been a challenge for sure. I still have to install a coolant over flow tank (ordered a cheap one on eBay). Then tidy up some more of my custom wiring, do all of the vacuum lines (dreading this step honestly).
It's been extremely difficult to even attempt to work on it in the last couple weeks. I was on vacation mid June and after that the temps in Michigan have been 85+ degrees with extremely high humidity. And trying to work in a poorly ventilated, at home garage is not fun with those kind of temps. I will be getting out there some more this week. I'm incredibly close to firing her up and it's very exciting!
Irace86.2.0 (07-01-2019)
Old 07-01-2019, 10:51 PM   #97
Irace86.2.0
Im kinda confused how the manifold runners are blocking the studs. Pics?
Old 07-01-2019, 11:03 PM   #98
Ashikabi
Ashikabi's Avatar
I'm not certain what he means but I'm not surprised. I wasn't happy with my CX parts either... Headers looked really cool though
Built Turbo K24 Swap? Calmwhiteguy Engine Swaps 31 02-13-2018 05:07 PM
Custom Grill Duct Backyard Build, Opinions? Doobster Cosmetic Modification (Interior/Exterior/Lighting) 22 08-04-2017 04:20 AM
Giving flat black wheels a dash of bronze? Expert backyard painters want to weigh in? Keenercarguy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 06-02-2017 09:15 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
Rwd-boxer's backyard exhaust fix RWD-boxer Engine, Exhaust, Transmission 9 06-11-2012 06:15 PM
