Old 07-04-2020, 11:26 PM   #1
Sumtingwong
Drives: 2013 Scion FRS Boosted Auto
Frs no crank no start, radio, clock, and window switches not working
Hey guys so being the idiot that I am i forgot to disconnect the negative battery cable while working on my car. No mods were added i just wanted to clean up the bay a little and while taking off a bolt, the ratchet sparked. Now when i go to try and start the car, there is literally nothing happening and to add on, the radio, clock, and windows arent working. Ive checked all the fuses and the battery tested good. Any other ideas?
Sumtingwong is offline   Reply With Quote
Old 07-04-2020, 11:58 PM   #2
alphasaur
friendly
Drives: 17' 86
Which fuses did you check? Both inside the car and engine bay?
Does cluster come on?
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 07-05-2020, 12:01 AM   #3
Sumtingwong
I checked every single fuse even if they're not associated to the problems i'm having. I went through and checked continuity at every point. The cluster comes on just the radio, clock and windows don't opperate.
Old 07-05-2020, 12:42 AM   #4
Well, Sumtingwong (are you putting us on with that forum name - ) .... even so, welcome to our forum -
There is a couple of big fuse looking things under the red cover on the positive battery terminal, you may wish to check to see if either or both of those are blown.
You do realize there are two fuse blocks, one under the dash and one under the hood?
Come back.
alphasaur (07-05-2020)
Old 07-05-2020, 12:46 AM   #5
Sumtingwong
Lol that was the point of the name. I checked the big fuses by the poitive battery connection look alright but havent tested them and yes i checked both under the dash and under the hood. Also looking further into whats not working, my mirros dont move, windshield wipers dont work, and ac doesnt opperate either. I'm so lost
The Following User Says Thank You to Sumtingwong For This Useful Post:
humfrz (07-05-2020)
Old 07-05-2020, 01:06 AM   #6
Allow me to ring up ol @soundman98 for you, he is pretty smart about these electrical things. He may not respond till morning, or till he gets his burnt finger out of his glass of vodka tonic after burning it lighting off fireworks -
Old 07-05-2020, 01:12 AM   #7
Sumtingwong
I really appreciate that. Thank you
Old 07-05-2020, 01:19 AM   #8
Also, you may wish to check out the appropriate relay.
https://www.ft86club.com/files/BRZwiringi.pdf
Old 07-05-2020, 01:56 PM   #9
Sumtingwong
Well this morning i tested the 2 main fuses on the positive battery and sure enough one of them was blown.
humfrz (07-05-2020)
Old 07-05-2020, 04:08 PM   #10
Glad you got er sorted out -
Old 07-05-2020, 06:36 PM   #11
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
glad you found it, as I was going to just post to look at those, but decided to read and see if you found it yet
If you ground out a main terminal like you did with your wrench, every car since who knows when has a main fuse like this in order to keep you from frying anything important. Sometimes those main fuses are expensive tho. Hope yours(mine too I suspect) isn't too spendy
JohnH is offline   Reply With Quote
Old 07-06-2020, 01:33 AM   #12
Sumtingwong
Nah luckily it was $15 online, that fuse saved me from thousands of dollars worth of damage. I have an ecutek license on the ecu and if i lost that i was gonna part the car out lol. Thanks for the help though guys
Part # for MY17 window switches? Suparu Cosmetic Modification (Interior/Exterior/Lighting) 5 02-01-2020 08:02 PM
Car won't start - doesn't try to crank at all, but lights are working HELP cdo221 Issues | Warranty | Recalls / TSB 28 06-06-2018 06:30 PM
Window switches not working right after battery swap jonbonazza Issues | Warranty | Recalls / TSB 9 01-10-2014 02:50 PM
stereo and clock not working FRSGIRL❤ Issues | Warranty | Recalls / TSB 6 04-30-2013 11:45 AM
