02-17-2016, 10:50 AM | #197 | |
- Andrew |
02-17-2016, 10:52 AM | #198 | |
- Andrew |
02-17-2016, 10:53 AM | #199 | |
- Andrew |
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | JohnH (07-28-2020), Mr.Impreza (02-17-2016) |
02-17-2016, 02:43 PM | #200 |
Mr.Fujitsubo
Drives: 2018 STI
Yeah, I was measuring from the fender. Thank you very much for the quick response!
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review |
The Following User Says Thank You to Mr.Impreza For This Useful Post: | Racecomp Engineering (02-17-2016) |
02-17-2016, 05:30 PM | #201 |
Drives: 2013 Brz C38 (bought not built :P)
Out of curiosity, what's your opinion on 18x9.5 lightweight wheels? (rays 57xtreme to be exact. Also keep in mind that I'm not stock, Kw c38; all bushing and mounts are solid; kw v3 coils; BBK, hence the bigger wheels). Ok it was also bought not built lol
02-18-2016, 10:55 AM | #202 | |
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
215/45R17 tire weight: 22 lbs 245/40R17 tire weight: 25 lbs 265/35R18 tire weight: 28 lbs So your wheels have to be 6 lbs lighter than the stock size before you break even on the weight increase, and even "lightweight" wheels weigh more as they get bigger. Those wheels are ~22 lbs according to the wheel directory, so you're probably looking at ~50 lbs per wheel+tire compared to a light 17x9 wheel (~16 lbs) and 245 tire at ~41 lbs. You've got some more power, so the balance is up to you, but you'll probably get the best net performance going with a light 17x8 or 17x9 wheel and 235-245 width tires |
The Following 4 Users Say Thank You to JozhGoober For This Useful Post: | ap5512 (02-19-2016), fumanchu1 (02-18-2016), Racecomp Engineering (02-18-2016), strat61caster (02-18-2016) |
02-18-2016, 11:13 AM | #203 |
Yeah you will be OKAY...but remember compound is generally more important than tire width if grip is your goal. So you will be even better with a slightly narrower wheel and a better tire.
My main point is that when I see 9.5s with 285 all-seasons...I see that as a waste (functionally). - Andrew |
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | fumanchu1 (02-18-2016), re-animator (07-10-2018) |
02-18-2016, 11:22 AM | #204 | |
Thanks for the answer, also thanks for your input @JozhGoober |
02-18-2016, 11:25 AM | #205 |
I'm aware that ideal size would be to reduce wheel width (and possibly go back to 17s but wheel gap eww lol) but I won't be doing so (limited budget) unless I either get a good trade deal for something comparable in smaller size or if I ever explode my wheels with a curb or two
02-18-2016, 11:54 AM | #206 |
We were happy with 18x8.5 wheels with 245s. Could have had some slight improvement with a 17 inch wheel. But they were BBS baller status wheels, so....even we make compromises sometimes.
- andrew |
02-18-2016, 06:46 PM | #207 |
Drives: 2014 Monogram FR-S Whiteout
I plan on running Enkei TS9's 18x8.5 +45 front and 18x8.5 +40 rear (staggered look yo) with 235/40 Michelin PSS all around coupled with Tein Mono Sport coils with about a 1 inch drop or just under it. (I plan on going with a complete whiteline bushing set and suspension geometry correction kit later down the road)
Is this a good pairing or am I hurting my handling characteristics? I scoured the internet for the most precise weight values and the best I could find put me at 2.3 lbs heavier per corner. I won't be running TPMS but I can't imagine that saves any weight worth mentioning. I hope to make up for that weight with a BBK later but whether or not it will clear is a completely different question. I understand 17's would be better but the looks of 18's are my compromise and little gift to myself. Not on stock power (JRSC C38 soon as I put it on). As I go up in power I plan on running the same wheels but changing tire compound and width which is why I am leaning towards 8.5 width and not 8. Hopefully I didn't leave anything out and there is enough information to go on. Thank you in advance for any advice as I don't know anything about suspension tuning. |
02-18-2016, 06:52 PM | #208 | |
Custom User Title
Drives: Asphalt FR-S MT
You can also run 245/35 on an 18x8.5.
02-18-2016, 07:34 PM | #209 | |
I understand it is not truly staggered, the reason is that currently I am running 20mm spacers front and 25mm spacers rear and the look is absolutely perfect! They are hubcentric spacers and I only run them on the street with moderate driving, just for fun and I can afford bearings when it comes time to replace prematurely worn ones. With those offsets, the wheels put me at 22mm front and 27mm rear. Dropping them 1 inch sucks them in another 2mm front and rear, the wheels will be sitting exactly as I want them. I am also hoping the slightly wider track in the rear helps reduce oversteer if only a little. With those offsets I will lose 18mm front and 13mm rear inner clearance and I read that there are no known fitment issues with that. Then again TS9's are not in the wheel directory? I am still confident though. I am fine not rotating. Depending on how much I get to make it to the track with my insane deployment schedule I will be replacing tires more often due to their age rather than their wear. I am just hoping I can accomplish these form goals in mind without compromised function. I don't want to run spacers as I will already need hub adapters for these wheels so staggered offsets seems to be the next best thing. I am willing to go through with this if performance is equal to or greater than OEM but not if it will be any worse. I know no one can know for sure without testing but I am hoping to get a good assessment from someone more knowledgeable than myself. |
02-18-2016, 07:52 PM | #210 |
Custom User Title
Hub adapters? Your wheel face isn't going to look any different. And that 10mm extra width isn't going to make nearly as much of a difference as an actual staggered setup.
I suggest you to just drop the car first. You can also run 5mm spacers with the 45mm offset to achieve 40mm. There is just no point getting two different wheels in the same width.
Similar Threads | ||||
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) | runny_yolk | Electronics | Audio | NAV | Infotainment | 120 | 01-29-2021 06:18 PM |
step 1 :buy frs in phx, step 2: drive to pikes peak | haymaker | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 08-21-2012 10:44 AM |
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:38 AM |
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:27 AM |
