Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-23-2017, 11:35 PM | #1 |
Drives: 2013 - Toyota 86
Drivetrain, axels, diff
Would it be a bad idea to upgrade the drive train, axels and diff around 2-4 weeks before throwing in the built engine and turbo kit? As in would it be harmful to the car as I'll be daily driving it for around a month before completed?
09-24-2017, 02:04 AM | #2 | |
The Dictater
Drives: '13 Red Scion FRS
Edit, assumed tranny was coming out too. If that's not the case, then ignore my first sentence. |
09-24-2017, 02:08 AM | #3 |
The Fail Boat
Drives: CWP S.B.
That sounds like a good idea actually?....cuz you get to break in the trans first?
But I guess you can do it at the same time too since it should be cheaper to do it all at once? |
09-24-2017, 03:43 AM | #4 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
That's exactly what I did, you can see my build page. I did the driveshaft first, then trans and diff with axles. Then put in a built motor and turbo kit. It will not harm or cause any ill effects.
The Following User Says Thank You to Drakiv For This Useful Post: | JamesK (09-24-2017) |
Similar Threads | ||||
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? | Frs30 | Engine, Exhaust, Transmission | 22 | 04-13-2020 10:23 AM |
Diff Mount Inserts install - Diff won't lower??? | ChRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-17-2017 12:07 AM |
Swap AT Diff with MT Diff | sydious | Engine, Exhaust, Transmission | 2 | 03-17-2016 02:59 PM |
WTB: SOCAL: rear axels :) | mr. slim | Want-To-Buy Requests | 0 | 11-04-2014 12:25 AM |
Drivetrain experts! Name this car! :) | aspera | Engine, Exhaust, Transmission | 200 | 08-15-2010 11:41 PM |
