Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
04-23-2021, 01:04 PM | #1 |
Drives: 17' steel 86
Can i swap my 86 key to an FRS key?
Is it possible to swap my toyota 86 key for a scion fr-s key. Personally a much bigger fan of the FRS key.
04-23-2021, 01:09 PM | #2 |
No. Or more accurately not without paying a pile of money. They keys are chipped for the car and there is no easy way to recode them.
04-23-2021, 01:09 PM | #3 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
a little confused..if you have an 86 key without push button start, isn't the difference between that and pre-facelift FRS key just the Toyota vs Scion logo..? if so, I'm pretty sure they are the same exact model and you can just replace the cover with the logo..
04-23-2021, 01:15 PM | #4 | |
Pre 17 Not a big enough difference to worry about but to each their own I guess.
04-23-2021, 01:55 PM | #5 | |
Reformed
My key.. |
04-23-2021, 02:14 PM | #6 | |
Certified Wumbologist
Drives: 2015 Scion FR-S
I also have the same exact key for my 2015 frs. Correct me if I am wrong but I believe it is "Post '15"?
04-23-2021, 02:18 PM | #7 | |
Sporadic Member
Drives: 2016 Halo FR-S M/T
This design might have debuted in 2015; my aunt's previous 2015 Camry used the exact same key fob. I can also confirm that the backs are completely interchangeable too (test fit her key cover with my key and it fit). If OP is just looking to replace the key cover, I assume he's going to need the VIN of a Scion made after 2015 (at least that's my experience when trying to acquire a Toyota key cover to replace my worn Scion one, may not be for every dealer though). |
04-23-2021, 02:34 PM | #8 | |||
What is this "key" you all speak of anyway? FOB crowd uber alles!
04-23-2021, 02:38 PM | #9 |
Reformed
manual car, manual key noob
04-23-2021, 02:40 PM | #10 |
More engaged in unlocking the door. Only a true door unlocking enthusiast will understand.
04-23-2021, 03:32 PM | #11 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
Switch it with the Scion IM's chunky switchblade key!
04-23-2021, 04:29 PM | #12 |
Drives: 17 86
04-23-2021, 05:35 PM | #13 |
Well there is a lot you can do while digging through your pocket for it.
04-23-2021, 06:06 PM | #14 |
has a funny hat
Drives: 2014 BRZ Limited
Why not both? Look down on the plebeians and enjoy the physical purity of manual actuation.
This is my keychain. I added a keyed steering lock so I can move the car around my garage without a battery in the car. Extra side benefit, FOB cloning car thieves won't get very far without steering. (A surprisingly valid concern for the size of Kalamazoo metro area (at least if vehicle theft reports on the community discussions apps are accurate)). |
Tags |
86 key, frs key, key fob |
Similar Threads | ||||
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-21-2015 11:38 PM |
Key Fob Swap | joergasm | BRZ First-Gen (2012+) -- General Topics | 1 | 10-02-2012 11:40 PM |
