Old 07-02-2014, 03:09 PM   #15
Trettiosjuan
Drives: GT86
The easiest 'road' to comfort is tire suspension. Lotsa sidewall... Stock suspension was (mostly?) developed on 16" wheels... Sorry can't help pointing that out, and I'm thinking of all the poor souls getting 18" and 19" and cheap coilovers and then being all surprised it ain't so comfortable on a nightmare road... (edit: now see stock wheels on your avatar. I also found them unusually harsh in their ride with no apparent benefit in road holding, hence my wheel choice....)
Another way is to add a lot of soft bushings and a lot of weight... Yep wrong car...
Trettiosjuan is offline   Reply With Quote
The Following 5 Users Say Thank You to Trettiosjuan For This Useful Post:
8R6 (07-02-2014), Grateful Dave (07-08-2014), NWFRS (11-08-2014), Racecomp Engineering (07-02-2014), steve99 (07-14-2014)
Old 07-02-2014, 03:56 PM   #16
CSG David
CSG David's Avatar
Originally Posted by DarkSunrise View Post
Haha this made me laugh. I've driven down Olympic before and you're absolutely right, it's got some rough patches.
Good thread topic btw.
Yea my 16kg/mm sprung TEIN SRC actually feel a little rough with the track setting. I actually have to back down maybe 1-2 clicks to make it nice. LOL
The Following User Says Thank You to CSG David For This Useful Post:
Captain Snooze (07-02-2014)
Old 07-02-2014, 04:21 PM   #17
DarkSunrise
DarkSunrise's Avatar
Haha balls of steel.
2022 BRZ Build
2013 FR-S Build
Old 07-02-2014, 04:31 PM   #18
CSG David
CSG David's Avatar
The valving is quite refined. Still the fastest coilover setup for the price.
Old 07-02-2014, 04:33 PM   #19
sprintamx
This may seem counterintuitive, but you might consider rear subframe bushing inserts to help pull everything together. In my experience--with adjustable Konis and relatively soft springs--the inserts helped to smooth out performance and unify rear-end dynamics. The performance of the dampers is, well, enhanced, since the car does not seem to be moving in several directions with each bump. Is it more "comfortable"? Hard to say. But, I do consider the car to be smoother now.
Here in the east, we have some real crappy streets and no rush to fix winter's devastation.
Inserts are relatively cheap, easily installed and easily removed.
One guy's experience . . .
sprintamx is offline   Reply With Quote
The Following User Says Thank You to sprintamx For This Useful Post:
Trettiosjuan (07-02-2014)
Old 07-02-2014, 04:36 PM   #20
Trettiosjuan
Drives: GT86
Same experience here
Old 07-02-2014, 05:05 PM   #21
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Racecomp Engineering View Post
With KWs or our RCE T2s it's still fine except for some of the really sharp big bumps, which still aren't completely awful. With Ohlins it's a little better. JRZ a step better than that.
- Andy
Then ya got yer Penske, which I believe @CSG Mike said you can setup to ride like a Lexus and handle like a Porsche...
Old 07-02-2014, 05:22 PM   #22
Grim-Reaper
Grim-Reaper's Avatar
Drives: GT86 '13 AT, Supra 3.0i Turbo' 91
What about your experiences with wheel width and offset?
Due to legal regulations 8 inch with 35mm offset or 8,5 with higher offset (45/48 somewhat) is maximum in Germany and people already talk about the influence to the steering by changing, yeah... German word is Lenkrollradius... The axis where steering would meet center of your tire right on street surface.
Lower offset would cause higher impact on the suspension, more tricky running after deep lines in the asphalt and so on.
How do you think about that when you can run even more extreme wheels and camber? Any experiences compared to bone stock OEM?
Grim-Reaper is offline   Reply With Quote
Old 07-02-2014, 05:24 PM   #23
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I use stock suspension, 27lbs* 16" forged rims with soft-sidewalled tyres.
I like this idea. Smaller rims, higher profile tyres.
Old 07-02-2014, 05:51 PM   #24
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Didn't the '14 year model get upgraded with Sachs dampers, assuming with better (more compliant) damping curves? Maybe you can score a used low milage set off a MY14 owner upgrading their suspension.
Old 07-02-2014, 05:53 PM   #25
Trettiosjuan
Drives: GT86
Yep. Basically, smaller lighter car works better with smaller, lighter wheels, all things considered...
In the US it seems at least Honda people have understood that...
Old 07-02-2014, 06:16 PM   #26
It's easy to make cars handle likes a Porsche
wparsons (07-03-2014)
Old 07-02-2014, 06:21 PM   #27
gramicci101
Off Topic
Fill the trunk with bags of concrete to simulate the weight of a rear-engined car?
The Following 5 Users Say Thank You to gramicci101 For This Useful Post:
andrew20195 (07-02-2014), cdrazic93 (07-02-2014), CSG Mike (07-02-2014), sprintertrueno86 (07-08-2014), wparsons (07-03-2014)
Old 07-02-2014, 09:57 PM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
If you can achieve that with a FWD car, hats off to you sir!
making seniors look bad, uberstupid
For those who ride, there's a group ride happening tomorrow if you're interested. Yamaha_R6 Northwest 3 03-07-2014 09:32 PM
Simple mods to improve handling while improving looks? Jinzen Scion FR-S / Toyota 86 GT86 General Forum 11 06-07-2013 11:48 AM
What's your other ride, winter ride etc. wtout86 Other Vehicles & General Automotive Discussions 14 12-07-2012 12:36 AM
Does the ride quality change with time?? BRZnut BRZ First-Gen (2012+) -- General Topics 22 12-01-2012 08:26 PM
