Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-05-2020, 08:13 PM | #1 |
Drives: 2015 BRZ Limited
Ramps vs Jack stands
I'm planning on installing a few bushings soon and was wondering whether ramps are fine or whether I should throw it up on jack stands. Reason I ask is some installs require the suspension to be unloaded while others it doesn't make a difference.
Bushings I plan to install: Whiteline Transmission Mount Insert Whiteline Subframe Inserts Perrin Rear Shift Bushing
Bone stock
11-05-2020, 08:16 PM | #2 |
Drives: 2018 BRZ
I've done all of these on jack stands.
As far as I know, you can't do the rear subframe inserts on ramps as that would load the subframe, not allowing it to drop to give clearance to put the top inserts in. |
The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post: |
11-05-2020, 08:21 PM | #3 |
The Dictater
Drives: '13 Red Scion FRS
100% jack stands.
The Following 2 Users Say Thank You to Spuds For This Useful Post: | DarkPira7e (11-05-2020), holeeray (11-05-2020) |
11-05-2020, 08:27 PM | #4 |
Rust bucket enthusiast
Ramps are good for looking. Jackstands are good for doing
The Following 7 Users Say Thank You to DarkPira7e For This Useful Post: | holeeray (11-05-2020), norcalpb (11-05-2020), Ohio Enthusiast (11-05-2020), soundman98 (11-05-2020), Spuds (11-05-2020), Ultramaroon (11-12-2020), x808drifter (11-06-2020) |
11-05-2020, 09:28 PM | #5 |
ProCrastinationConsultant
i've had ramps shift too many times while loading/unloading. way too many close calls and additional bumper scratches for no reason.
i always do maintenance on jack stands. even oil changes. they're more solid, and easier to place safely.
The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (11-06-2020) |
11-06-2020, 08:03 AM | #6 |
Site Moderator
Drives: Stuff
Old school ramps, like early 90s rhino ramps, are great. Modern ones suck.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
11-06-2020, 07:44 PM | #7 |
i've had 2 old sets of steel 1970-1980 vintage Sears brand ramps. i've had both sets randomly shift while driving up/down them.
and then i end up dragging the jack out anyways to get it off the one ramp that is now twisting the frame and tweaking the bumper. figure i might as well cut out the middle man and just use the jack from the beginning.
11-06-2020, 07:50 PM | #8 |
Panda Trueno
Drives: No twin now.
The low profile, long race ramps are great. Anything else, nah. I've had issues with anything else I've tried except on a heavy truck or something.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post: | holeeray (11-08-2020), soundman98 (11-06-2020) |
11-07-2020, 11:37 AM | #9 |
Drives: 2015 FRS - FFR GTM
I use these cribs from race ramp. When not working on suspension they are great!!
2015 FR-S - One Day I'll Finish The Swap |
The Following 2 Users Say Thank You to gtpvette For This Useful Post: | holeeray (11-08-2020), soundman98 (11-07-2020) |
11-10-2020, 10:58 PM | #10 |
Drives: 2013 FR-S Series 10
if you use those ramps inspect the shit out of them before every use. i've seen those rhino ramps crack now and then.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
Similar Threads | ||||
Harbor Freight Recalls Jack Stands Meant to Replace Recalled Jack Stands | Tanstin | User/Vendor/Sponsor Reviews, Feedback, Comments | 9 | 07-16-2020 12:24 PM |
Jack stands help | cat94 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 24 | 02-02-2017 11:50 AM |
WTB: Low profile floor jack and jack stands! | lupindub | Want-To-Buy Requests | 2 | 11-26-2015 11:03 PM |
FS: HF Jack $65, Ramps $45 | retrosmiths | Mechanical Maintenance and Tools | 1 | 10-22-2014 02:26 PM |
ramps + jack stands | so26 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 04-23-2013 04:43 PM |
