Old 04-04-2023, 01:54 AM   #1
Nmstec
Drives: Frankenstein of parts
GT86/FRS/BRZ Electric power steering control solution
For those who know what to do with it, run wild!
https://github.com/NMSTEC/GT86-FRS-BRZ-EPAS-solution
Please make sure to read the notes, as this was a solid 3 days of figuring out all its bullshit.
Nmstec is offline   Reply With Quote
The Following 4 Users Say Thank You to Nmstec For This Useful Post:
alphasaur (04-06-2023), Jdmjunkie (04-04-2023), pope (04-04-2023), RedReplicant (04-04-2023)
Old 04-06-2023, 02:33 PM   #2
RACECAR go brrr!
Custom Switch Panels!
RACECAR go brrr!'s Avatar
Drives: 2015 Subaru BRZ Series.Blue
Wait... does this allow you to fix those brief moments where the power steering gives up under load during autocross???
Order your own custom Toyobaru switch panel at www.racecargobrrr.com!
RACECAR go brrr! is offline   Reply With Quote
Old 04-06-2023, 04:27 PM   #3
RedReplicant
Drives: None
Unfortunately not, but it will help you build your own assist map
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
Jdmjunkie (04-06-2023)
Old 04-06-2023, 05:37 PM   #4
Nmstec
Sorry not yet, this can HELP with it if you drop the assist, but the problem is in the hardware. RedReplicant and I are looking into doing prius controller swap that doesn't have this issue.
The Following 2 Users Say Thank You to Nmstec For This Useful Post:
Jdmjunkie (04-06-2023), RedReplicant (04-06-2023)
Old 04-06-2023, 07:47 PM   #5
Nmstec
GOOD NEWS. We have a solution and it seems like it will work. RedReplicant will test and we will give the answer right after!
BAD NEWS. Hardware changes will be required.
BAD NEWS FOR YOU GOOD NEWS FOR ME: You will need my controller. Technically if I make this a kit, I will drop the price for the controller as part of the kit.
Hint:
DocWalt (04-13-2023), RedReplicant (04-07-2023)
Search this Thread:
Advanced Search
Electric Power Steering Gone chiefshayan Issues | Warranty | Recalls / TSB 11 08-16-2023 12:45 PM
Electric power steering and steering column part info raspec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-12-2021 05:27 PM
Electric Power Steering ArtS Electronics | Audio | NAV | Infotainment 0 10-31-2016 08:19 AM
Electric power steering assist to remote control SeanBlader BRZ First-Gen (2012+) -- General Topics 6 01-07-2014 10:16 AM
Electric Power Steering control module? slicktop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-21-2013 08:38 PM
