06-23-2022, 06:52 PM | #211 |
Drives: 86
Can anyone confirm that a 2020 Head unit from a Toyota 86 will be a straight plug and play swap into a 2013 Toyota 86 GTS?
Just want to make sure I won't run into any of the issues in this thread: https://www.ft86club.com/forums/show...2020+head+unit Also, if the issue with the amp bypass will come into play with this swap? Cheers all. |
06-24-2022, 10:02 AM | #212 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Ads (06-25-2022) |
06-25-2022, 01:48 AM | #213 |
Drives: 86
Ok, good to know. Thanks for that Tcoat!
06-25-2022, 08:07 AM | #214 | ||
Drives: 86
06-28-2022, 09:51 AM | #215 | |
Master Collaborator
You can use the antenna amplifier output to turn the door speaker amplifier on. Read my DIY for reintegrating the stock amplifier into 2020 model year twins. |
The Following User Says Thank You to FR-S2GT86 For This Useful Post: | Tcoat (07-01-2022) |
07-01-2022, 02:44 AM | #216 | |
Drives: 86
EDIT - I think I am getting my head around it now. I will create the adapter so I don't have to splice into OEM wiring and then plug in the bypassed plug in the back to the amp. Is that pretty much it in a nutshell? So I can just buy these adapters: https://www.amazon.com.au/Metra-70-1.../dp/B0002BEQJ8 I believe the above is the same plug as the Scosche TA02RB? And this: https://www.amazon.com.au/AUTOHAUX-7...%2C1320&sr=8-7 ..is the same as the TA02B? Last edited by Ads; 07-01-2022 at 03:22 AM. |
07-01-2022, 05:01 AM | #217 | |
Master Collaborator
Yes to all three questions. Also, you will need the antenna adapters as well. Keep in mind that those instructions are for a North American model. If your car is an AUS model, some of the wiring MAY be different. In that case, you are on your own. You should be familiar with the use of a multimeter in order to verify the proper connections. I suspect they will be very close to the wiring in the NA models. |
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post: | soundman98 (07-01-2022), Tcoat (07-01-2022) |
08-27-2022, 02:32 PM | #218 |
Drives: 2014 BRZ Limited
Hi All, trying to figure out if this stereo has changed over the past couple of years? I search the same part number and all the local Toyota dealerships selling the unit look different now (more buttons and a volume knob) compared to the images provided where the headunit only has 4 buttons (no knob). Any help would be appreciated!
09-09-2022, 06:02 AM | #219 | |
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
But you will not get this radio, PT296-18190-20 will be the radio with only 4 physical button on the left like you've seen on this thread.
09-10-2022, 11:23 AM | #220 | |
The Following User Says Thank You to oh bui For This Useful Post: | trueno86power (09-12-2022) |
08-03-2023, 10:45 PM | #221 | |
Drives: 2013 Scion Frs
08-07-2023, 03:19 PM | #222 |
Could you attach a pic of the back up camera working on that radio? Also on your 2016, is your back up camera wired into the 24 pin or 28 pin?
11-08-2023, 01:13 PM | #223 |
Drives: '13 WRB 6MT BRZ Limited
Can someone help me here? I’m trying to clarify if 2020 Subaru head unit p/n 86271ca690 is a plug and play into 2013 gen1 BRZ? Amp bypass needed but I intend to install a backup cam as well at same time as hu swap. Can I accomplish all?
2013 BRZ Limited WRB
11-09-2023, 06:28 AM | #224 | |
Master Collaborator
https://www.ft86club.com/forums/showthread.php?t=145959 If you scroll down to the second post, you'll find a less expensive alternative procedure to connecting the antenna and amplifier leads together. Trust me on this, as long as the remaining system is stock and all you're wanting to do is upgrade to the Harman head unit, you'll want to keep that rear amp in play. |
The Following User Says Thank You to FR-S2GT86 For This Useful Post: | bcj (11-09-2023) |
Tags |
audio, head unit double din, mp3, stereo, usb port |
Similar Threads | ||||
2020 86 TRD info? | Vr4gasmtt | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 08-27-2019 02:41 PM |
Android based stereo vs. stereo w/ Android auto | redlined600 | Electronics | Audio | NAV | Infotainment | 12 | 02-24-2019 02:53 AM |
2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo | brzsubarusti13 | Audio/Visual, Electronics, Infotainment, NAV | 11 | 02-27-2016 06:33 AM |
Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo | dssence | Electronics | Audio | NAV | Infotainment | 0 | 01-27-2015 06:43 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
