Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
11-16-2021, 02:06 PM | #1 |
Drives: 2015 FRS
Question about FRS longevity
Hello all,
I've been having some serious oil leak issues and a mechanic told me I should think about trading my car in as these cars apparently don't last beyond 200,000 km. My car is a 2015 FRS has 221,000 km on it, it's my main car. I oil change it 1000 km before it's due almost always (sometime 1500km), and do just about any repair or maintenance needed on it. The car is paid for and I love it a lot. I have heard that the engine gets oil leaks around the timing chain (a mechanic described it as a type of sweat). He said it would take 3 days to repair this but it's not needed now. So two questions, can this car get to 300,000 km and beyond with this kind of issue? Or, should I just get rid of it? |
The Following User Says Thank You to xyrodon For This Useful Post: | humfrz (11-20-2021) |
11-16-2021, 02:34 PM | #2 |
If it helps people in UK have 150K miles on the car and still running strong! No reported engine issues or oil leaks.But I haven't yet seen a car do 200K+ miles..or 300K Kms.
I wouldn't change it till the engine or a major part gives up as you have it all paid for and limited liability now. Sent from my SM-G781B using Tapatalk |
The Following User Says Thank You to Brz-123 For This Useful Post: | humfrz (11-20-2021) |
11-16-2021, 04:27 PM | #3 |
Drives: 2017 Toyota 86 860 Special Edition
From my experience Subaru engines are hard to kill if maintained properly. Our engines are fairly sturdy and robust. I've seen some Subaru engines well over 200k miles, but that's if you take care of it and don't beat the snot out of it like some people do.
So long as you keep up with the maintenance and oil services, I see no reason to consider getting a new car unless you want to. No reason to give up on a car just because its high mileage. However, depending on how the leak progresses, you may or may not have to have it fixed before 300k. Keep an eye on it and see where it takes you. If you find you are having to add a lot of oil between services, it might be worth considering having that service done if you plan to keep the car. I wouldn't sell it, personally. |
11-16-2021, 04:48 PM | #4 |
Drives: car
@xyrodon how big is the oil leak? You said it was a serious leak but if its just "sweating" as your mechanic is, then that's nothing. My car has had the small seepage behind the camshaft seal its whole life and I'd say it does nothing to affect the longetivity of the car, as long as you're keeping good oil in it.
The things that I'd say would affect the longevity of the car more is wear on the drivetrain components, body, mounts. Most cars are due for having mounts and bushings replaced or upgraded by 100,000 miles. Plus years of driving through salt and slush, you're likely to have parts rust off your engine rather than run into trouble with a miniscule leak. |
11-16-2021, 07:05 PM | #5 |
Drives: '13 Whiteout
Proper oil and overall maintenance and no telling how long it'll last. Hard driving will contribute to lesser miles.
11-16-2021, 07:36 PM | #6 |
All engines can develop seepage when the miles build up. Just don't let the oil level drop too low and all is fine. If you start getting puddles under it when parked then it is time t think about getting it fixed. There is no way it is a "three day" job.
As far as miles go, as stated, maintenance and how it is driven plays a much larger part than what kind of car it is. You mechanic is talking out of his ass. There are many many cars on here running higher mileage than you have. Hell my 2014 STARTED it's track time at around that mileage! https://www.ft86club.com/forums/showthread.php?t=143847
11-17-2021, 10:04 AM | #7 | |
Drives: 2015 FRS
Hi, Thanks for your reply. I appreciate all the replies from all of you. So question for you - why isn't fixing the leak a 3 day job? In terms of caring for my car, it's mostly highway driven. Yes, I drive pretty damn fast but I have drifted once in my whole life on this car lol. Other than that, she's well taken care off. |
11-17-2021, 10:33 AM | #8 | |
Here is some tech info for you. https://gt86stuff.onrender.com/t3Por..._rm_index.html
The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (11-20-2021) |
11-17-2021, 03:01 PM | #9 |
TRACKBREAD
My dealership had the engine out and back in for valve springs in less than 3 days, and they resealed the timing cover and did the clutch.
So 3 days to reseal the timing cover is absolute BS. Last edited by Yoshoobaroo; 11-17-2021 at 03:59 PM. |
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
11-20-2021, 12:30 AM | #10 |
Well now, that all depends -
11-20-2021, 12:41 AM | #11 |
Dismember
Drives: 2013 Red Scion FR-S
It's a 90 day job if I do it. 30 days for the first try. 30 days of avoiding redoing it because I fucked it up. Then 30 days again.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post: | soundman98 (11-20-2021), Ultramaroon (11-20-2021) |
11-20-2021, 12:47 AM | #12 | |
Bubba says the engine is good to go as long as it doesn't take more than a quart of oil a week. As they say in the old country, "why get rid of it if it ain't broke" - |
The Following User Says Thank You to humfrz For This Useful Post: | bcj (11-20-2021) |
11-20-2021, 01:29 AM | #13 |
義理チョコ
First I get a practice engine...
The Following User Says Thank You to Ultramaroon For This Useful Post: | EAGLE5 (11-20-2021) |
11-20-2021, 07:31 AM | #14 |
Meow
Drives: GT86, Volvo 996
If you can't see a difference in the oil level between oil changes interval, I wouldn't even bother to think about it.
The Following User Says Thank You to alex87f For This Useful Post: | Yoshoobaroo (11-20-2021) |
Similar Threads | ||||
Alignment Shop in SD and quick question question | JohnTran619 | Southern California | 5 | 11-21-2018 01:40 PM |
Turn Signal Relay Question (Dumb Question) | Chimera | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-23-2017 01:58 AM |
Engine Longevity? | SpidyJ | Engine, Exhaust, Transmission | 201 | 08-08-2016 12:42 PM |
Longevity of the the Twins? | FRSBRZGT86FAN | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 04-13-2014 03:51 AM |
Longevity/Reliability of Enhine | Mark Ducati | Forced Induction | 10 | 11-05-2013 09:43 AM |
