Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-23-2023, 07:31 AM | #1 |
Drives: Toyota GT86 GTS
Frt stainless steel line query
I purchased a pair of frt HEL stainless steel brake lines but they didnt come with new banjo bolts just the washers. Am I ok the use the OEM bolts or would it be best to try and source new bolts from HEL.
Also any idea what size I would need to order please. Thanks in advance. |
07-23-2023, 10:01 AM | #2 |
Drives:
I thought the banjo bolt was the fitting that is crimped to the end of the hose.
I reused the screw that secures the banjo to the caliper and the hardlines. Sent from my Pixel 6 using Tapatalk |
07-23-2023, 10:30 AM | #3 |
Drives: 2016 Scion FRS Release Series 2#439
Re-use the banjo bolts with the supplied new crush washers. Apply the OEM spec torque which I cannot recall but know it’s very low.
Edit: just checked the online manual. 13 #/ft is the torque value. Enjoy!
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) Last edited by Muskoka800; 07-23-2023 at 10:35 AM. Reason: New info |
07-23-2023, 12:02 PM | #4 |
Similar Threads | ||||
Stainless Steel Brake Line Brands | Michael | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 03-13-2017 06:05 PM |
FS: New Goodrich Stainless Steel Brake Line Complete Set | F1point4 | Brakes, Suspension, Chassis | 3 | 08-26-2015 04:34 PM |
PHR Stainless Steel Black Clutch Line | Powerhouse Racing | Transmission and Driveline | 5 | 10-07-2013 10:24 AM |
Stainless steel brake line upgrade? | 6-Shift | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 06-13-2013 04:43 PM |
