Forced Induction Turbo, Supercharger, Methanol, Nitrous |
01-08-2021, 02:47 AM | #15 | |
Drives: Q5 + BRZ + M796
Regardless of all that unknown conjecture, it is definitely possible to design a CARB legal turbo kit. CARB seems lightyears ahead of where they were in the past with making a reasonable path for getting CARB legal parts to market. I believe much of this has to do with the advent of computer controllers like ECUTEK, which is what is actually lightyears ahead of older air/fuel controllers. Works makes a CARB legal turbo kit for the 86 by building the turbo kit off the overpipe, so the catalysts aren’t removed or modified. Flyin’ Miata makes a CARB legal turbo kit for the ND Miata. They provide four options: buy their downpipe with a new cat, or send in your header, and they will cut it off and weld on your cat to a downpipe, or cut off your cat and send just that to them to save on shipping costs, or cut and weld your own downpipe using unfinished sections they ship with the kit. The Greddy turbo kit for the 86 has a test pipe in place of a catted pipe, which is only sold on JDM versions, but they could have made a CARB legal kit, IMO.
02-02-2021, 01:01 PM | #16 |
Drives: 2010 Nissan GTR
There you have it, full boost by about ~3500 RPM....giving you nearly 4000 RPM of powerband!
The new G500X, comparable in performance to the G25-660 turbocharger in spool, is among the fastest spooling 550+ whp turbochargers on the market! #RealResults #ProvenPerformance |
The Following User Says Thank You to spdbydesign For This Useful Post: | sroby (05-18-2021) |
05-10-2021, 05:07 AM | #17 |
Drives: TRD R.S. 1.0 FRS
When will these be for sale?
05-10-2021, 10:32 AM | #18 |
Drives: 2016 Toyota 86
05-18-2021, 04:15 PM | #19 |
Drives: 2016 Subaru BRZ
The Following User Says Thank You to Trueweltall For This Useful Post: | DarkPira7e (05-18-2021) |
Similar Threads | ||||
Coil Bind/Pillow Ball/Spherical Bearing Tein Flex A | VOSS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 12-19-2019 08:29 PM |
SB18-077 *BRZ ALL, Flywheel assy and ball bearing | Trap63 | Issues | Warranty | Recalls / TSB | 0 | 05-29-2018 03:26 AM |
SBD Announces the SBD500X Ball-Bearing Turbo Kit for the FT86! | spdbydesignchris | Forced Induction | 1 | 10-20-2016 10:12 AM |
FS : Trailer Hitch/Ball mount/Ball/T-connector | Sehwan Kim | Exterior Parts (Aero, Lighting, Etc.) | 3 | 02-11-2016 01:57 AM |
5 spoke TRD wheels 54mm center bore | MikeR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 03-11-2015 12:39 PM |
