Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 12-28-2021, 01:43 PM   #1
MisterGoober
Drives: IS300, WRX, STI, Bicycle
12V Outlet - Glovebox only? Radar Detector Install
Was installing my radar detector, and will likely hardwire at some point. The only 12V outlet I could find was inside the glove box, is there another one hidden someplace?
Any suggestions on hardwiring? Was thinking of using the wires in the mirror, but curious if there's a better way?
MisterGoober is offline   Reply With Quote
Old 12-28-2021, 01:57 PM   #2
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
That's the only 12V outlet in the car.
As for hardwiring, I was looking at the mirror wires too. The car already has a prerun harness for the homelink mirror which includes power (I assume 12V), the wires for this harness are inside where the dome lights are.
I need to look into how much power the homelink uses and see if the wires can handle the radar detector as well.
If you don't have a homelink mirror then this is easy enough just have to wire it up to the unused harness above the dome lights.
Interceptor777 is offline   Reply With Quote
Old 12-28-2021, 07:18 PM   #3
tenderization
Drives: 88 RX-7, 2022 BRZ
I prefer just using a 12V outlet over hardwiring despite how ugly it looks. Just routed the Uniden R3 wire straight down from the plug in the glovebox (putting the wire behind the glovebox itself). I tried going to the left at first but it seemed like it was getting caught on something. Not very stealthy and you lose access to the mute button on the plug but it'll do.
The coiled wire also wedges nicely between the glovebox/center screen area for the ultimate in low-effort jank install.
tenderization is offline   Reply With Quote
Old 12-28-2021, 08:58 PM   #4
MisterGoober
Just did the same, also couldn’t get the wire through the left side. I didn’t see a fuse box in the driver’s footwell, but didn’t look too hard. If the fuse box is nearby, I’ll eventually just use an “add a fuse” accessory and run it up the driver’s A-Pillar and headliner. For now, the glovebox will do the trick though
Old 12-30-2021, 08:18 PM   #5
tenderization
Are you using a blendmount or something else? Curious if the blendmount fit guide can be trusted.
Wire radar detector to 12V Glovebox iconic Electronics | Audio | NAV | Infotainment 5 07-16-2019 07:48 PM
Radar Detector UchihaFanBoy Electronics | Audio | NAV | Infotainment 23 03-26-2015 09:55 AM
Cop radar detector poison1916 Scion FR-S / Toyota 86 GT86 General Forum 50 05-08-2014 12:27 PM
Tristate Radar Detector/Laser Jammer install? #87 NY / NJ / CT / PA 5 06-24-2013 07:40 AM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
