Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
05-04-2017, 07:03 PM | #71 |
Driver of Sweet Vehicles
Will these wheels clear the 2017 Brembos? Tire Rack lists the 7.5" +35 and the 8" +48 both as compatible with the Performance Package, but doesn't list the 8" +35. But if the 7.5" +35 fits, there's no reason the same wheel in 8" wouldn't clear them, right?
I'm not super experienced with wheel specs so I'm worried about getting wheels that won't fit right. |
The Following User Says Thank You to Vdub For This Useful Post: | NLS8520 (06-24-2017) |
05-04-2017, 07:22 PM | #72 | |
Drives: SWP WRX HATCHBACK
17x8 +35 You will have to search under 2004 Jetta Sedan on Tire Rack. |
05-04-2017, 08:40 PM | #73 |
Thanks. Sure wish Tire Rack would make browsing wheels not so dependent on pairing them with a specific car.
05-04-2017, 10:16 PM | #74 |
Drives: 2019 Mazda Miata RF
I had to "sign" a waiver when I bought my wheels, since the +35 isn't on their approved fitment list. Funny thing is, they have other 17x8 +35 wheels that are, lol
04-24-2020, 10:38 AM | #75 |
Drives: 2013 Scion FRS
Reviving an old thread here , but here goes.
For the owners of these wheels, did you guys have to get any special hub centric rings? I've heard OZ uses a different style but I'm not sure how to get them as I bought my wheels used. Did Tire Rack just supply you with a set or? If some one could clear that up that would be much appreciated. Thank you. |
04-24-2020, 10:53 AM | #76 | |
Drives: 2015 BRZ
For example: if a wheel has a hub bore size of 73 you need to purchase 73mm to 56.1mm hub ring size. Again this is just an example im not sure what the size you will need for your OZ Wheels. Hope this helps... |
02-16-2021, 06:43 PM | #77 |
02-16-2021, 08:30 PM | #78 | |
Drives: 17 Asphalt 86
As far as brembo clearance, +35 pushes wheel farther out. If +48 fits, +35 should too. |
02-17-2021, 09:36 AM | #79 | |
https://www.ft86club.com/forums/showpost.php?p=3352334 Last edited by ThatYeti; 02-17-2021 at 01:14 PM. |
02-19-2021, 04:19 PM | #80 | |
Good luck with your search. Hopefully your have better luck than me. Post them up when you get them |
04-22-2021, 06:40 PM | #81 |
Drives: 2020 Toyota GT86
Don't see a separate thread for 17x7.5 +35 so I figured I'd post here.
No pics yet, but I just ordered mine in black from Tire Rack yesterday, so now comes the slow impatient wait for them to arrive!
This post sent using 100% recycled electrons.
05-08-2021, 05:43 PM | #82 |
I'll have to get some better pictures when it's not raining, but here are a couple of quick ones...
The Following User Says Thank You to bucketfoot For This Useful Post: | SG02WRX (05-13-2021) |
Similar Threads | ||||
Wheel Directory: OZ Ultraleggera 18x8.0 +48 | AkaJabari | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 54 | 11-02-2022 03:02 AM |
Wheel Directory: OZ Ultraleggera 17x8.0 +48 | Mageep | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 104 | 04-11-2021 12:03 AM |
Wheel Directory: XXR 527 17x8.25 +35 | MF_DEUCE | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 41 | 12-25-2019 06:37 PM |
Wheel Directory: XXR 535 17x8.25 +35 | PineappleFriedRice | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 10-24-2014 08:27 PM |
Wheel Directory: XXR 522 17x8.0 +48 | STEVEOSTI | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 12-13-2012 12:39 AM |
