08-27-2020, 11:30 PM | #3837 |
Drives: 2017 BRZ Series. Yellow
I threw in the act heavy duty pp and organic clutch disc with their streetlite flywheel and it feels great. It takes a little getting used to the lighter flywheel but the way it shifts through the gears now feels amazing. I'm currently waiting on some tech support for my SC but it should be more than enough to handle it until I build my motor. I think it's rated right around 280ftlbs
The Following 2 Users Say Thank You to aKaGorganZola For This Useful Post: | ArrrBussiere (08-28-2020), CSG Mike (08-28-2020) |
08-28-2020, 01:44 AM | #3838 | |
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | ArrrBussiere (08-28-2020) |
08-28-2020, 03:08 PM | #3839 | ||
Drives: 2014 Subaru BRZ SC & 2018 Tacoma
Also doing rear main seal at the same time as well Thanks everyone!!
The Following User Says Thank You to ArrrBussiere For This Useful Post: | jflogerzi (09-01-2020) |
08-28-2020, 03:43 PM | #3840 | |
Drives: Scion FRS
I went with an ACT kit, but regret bit not staying with a stock flywheel. |
The Following User Says Thank You to MaxTurbo For This Useful Post: | ArrrBussiere (08-28-2020) |
08-28-2020, 03:50 PM | #3841 | |
08-29-2020, 01:34 PM | #3842 |
Drives: 2013 Black BRZ Limited
Has anyone had issues passing OBD monitor readiness checks while having the kit installed? On the delicious tune, my oyxgen sensor monitor would never register as complete, even after a reset and 300 miles of highway and city driving. Unhooked the D-Box and went back to the Edelbrock CARB tune, 120 miles later and now my oxygen sensor monitor is complete but the Evap system monitor is incomplete. I'm doing aimless drives on the highway at 55mph to try and trigger the test.
The Following User Says Thank You to taiguy For This Useful Post: | CSG Mike (08-31-2020) |
08-29-2020, 01:51 PM | #3843 |
Drives: Toyota Supra 2JZGTE VVTi
Usually the EVAP monitor needs the fuel tank to be refueled or at a certain level for a certain amount of time to complete.
The Following User Says Thank You to Silvermk2 For This Useful Post: | CSG Mike (08-31-2020) |
08-31-2020, 04:29 PM | #3844 |
makes sense. had to disconnect the battery recently, so I'll be starting at square 1 again. the hard part is finding excuses to drive anywhere these days.
09-01-2020, 03:07 AM | #3845 |
Drives: 2019 PP BRZ
So I currently have the JDL uqfp on my car right now but thinking about switching to the JDL dual resonated front pipe, would a retune be necessary when swapping out the front pipe?
09-01-2020, 01:41 PM | #3846 |
Drives: Scion FRS
Any changes downstream the header should not require any tuning. Maybe something drastic like open dump after the header or the opposite (a big flow obstruction), but even then... your fuel should still be good.
09-01-2020, 05:55 PM | #3847 |
At the minimum I would recommend having your tuner review a log to see if a change is needed.
09-04-2020, 04:09 PM | #3848 |
Drives: 2013 FR-S Series 10
Sorry in advance for an oil debate, am i stupid for still using 0w20? Keeping in mind the climate here is mild bay area weather. I know it's for fuel economy but i figure the light weight during cold starts has to be beneficial.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
09-04-2020, 11:23 PM | #3849 |
Drives: 2014 WRB BRZ Limited
So after about 500 miles on this kit, I'm thinking I should probably add Radium dual catch cans. It seems like a lot of people do this at install time.
How easy or hard is it to do after the Edelbrock kit is installed on the car? I wasn't sure how easy it was to access the necessary hoses. Is there some documentation somewhere as to the proper connections to make when you have the Edelbrock kit on the car? |
09-05-2020, 12:21 AM | #3850 | |
Drives: 2016 Scion FRS Halo
Here's a quick rundown. Passenger side PCV valve connection that is currently connected to SC goes to "can" rerouted .. then the return hose from can to PCV connection on SC, which you would initially disconnect. This will probably require a joint from the PCV valve on the block to the can, which is fine if secured. Probably will do some hose trimming as well. Driver side can, even easier really.. currently connects to air box. Disconnect reroute to can with supplied radium hoses. Then run return hose from can to airbox to your liking with supplied hoses. http://data.radiumauto.com/PublicDocs/19-0073D.PDF They have new unit it looks like too that mounts to the inside or medial side of the battery. It's about the same price for both of the older design, it may or may not be better, but I do kind of like the way they did it.. might take a look In saying all this and that it is a fairly easy job. Don't feel rushed. And if I were going to I would start with passenger side if doing one at a time. On a pretty mild tune that I'm waiting to be worked on right now on a dyno, I have about 500 NA 500 SC on the cans. So about 1000 miles total. The dipstick is fairly dry on the driver side. Mild residue (which is something but pretty minimal) on the passenger side dipstick.. with no sign of pooling at the bottom yet for either. So I think that is more important side if doing one. I want to add in this post so I don't just make another post. It seems especially in hot environments that the oil cooler placement if put in front of the LTR can negatively affect to a significant degree the cooling for the SC so that the air can become heat soaked. Makes total sense.. I'm working on this right now with David out of DD Performance Research west of Houston and will post updates as possible. Maybe this is already well known and I overlooked it but if not.. definitely want to keep it in mind |
The Following User Says Thank You to AKITA For This Useful Post: | BR-ZED (09-06-2020) |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
