GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
09-09-2022, 03:06 PM | #71 |
Here in VA it's part of state inspection to pass visual, and in the last couple of years it has become stricter. No one ever checked anything before. Now they do. It's been some time since I've read the laws, but I believe it requires "OEM or OEM replacement" parts in regard to anything emissions or sound related. Now cops won't pull you over for this stuff unless it's blatantly obvious, but if you're being an ass and getting pulled over, they will ticket you for it. Some counties are worse than others.
The Following User Says Thank You to KillerBMotorsport For This Useful Post: | Tcoat (09-09-2022) |
09-09-2022, 03:34 PM | #72 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Tcoat (09-09-2022) |
09-13-2022, 11:36 AM | #73 |
Drives: Crapcan
To bring this back to light. I asked why they deleted comments questioning their gains and their word for word response is "Because we are addressing all questions in the next video."
When asked about the low baseline this was the response. "That’s exactly why it was done the way it was done. There’s no way to skew numbers doing back-to-back, same-day testing. Dynos are a tool and are best used this way when comparing numbers. There could be many factors for this discrepancy, like wear from the ton of silicone inside the engine. Heat is a major factor in power production. Even with a correction factor, it is never 100% accurate. The car made 210-212whp in a cool 60*F day off the lot. It has never made 210whp ever again and I have dyno’d it several times. You can expect a gain over any “base number” with this header, if you perform back-to-back testing "
09-13-2022, 12:17 PM | #74 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Fixed The issue is that 99.9% of Dynojets do not have absorbing capabilities. As mentioned, this makes them great to compare numbers for part development, but terrible for tuning. The ability to do steady state tuning (i.e. closed loop speed control) is utterly critical for producing a robust tune.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
09-13-2022, 01:27 PM | #75 |
Drives: 2013 frs red
I wonder if the cat in the stock header failed prematurely or the stock ecu is programmed to pull timing after the test drive lol
09-13-2022, 02:27 PM | #76 | |
Drives: '23 BRZ Limited
They chop the cat, completely hollow it out and weld in a pipe that matched the size of your current exhaust and weld it back on. Bang, you passed visual.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
09-13-2022, 02:28 PM | #77 |
You know how these guys really screwed up though?
They probably didn't pull the charcoal filter from the airbox for another 10hp.
The Following 3 Users Say Thank You to OkieSnuffBox For This Useful Post: |
09-13-2022, 03:10 PM | #78 |
Drives: Crapcan
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | OkieSnuffBox (09-13-2022), x808drifter (09-13-2022) |
09-13-2022, 03:30 PM | #79 | |
Drives: #337 2017 Toyota 86
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
09-13-2022, 04:01 PM | #80 | |
09-13-2022, 04:37 PM | #81 |
Drives: frs
This thread derailed very fast, from suspicious gains to EPA laws
09-13-2022, 05:00 PM | #82 |
Drives: Crapcan
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
09-13-2022, 07:42 PM | #83 |
Drives: frs
09-13-2022, 07:45 PM | #84 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | PulsarBeeerz (09-13-2022) |
Similar Threads | ||||
2Gen twins vs many drag racing | PulsarBeeerz | BRZ Second-Gen (2022+) -- General Topics | 10 | 01-16-2022 09:50 PM |
JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
