GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
09-05-2022, 06:17 PM | #15 | |
That is a supposedly massive gain just for a cat removal.
09-05-2022, 08:03 PM | #16 | ||
That being said, as has been discussed ad nauseum (and demonstrated by the above tests), de-catting on modern cars makes very little difference compared to any number of other changes. |
The Following 2 Users Say Thank You to Dake For This Useful Post: | Stonehorsw (09-05-2022), Tcoat (09-05-2022) |
09-05-2022, 08:37 PM | #17 |
Drives: JRSC BRZ SOLD
I am trying to get a bit more info from OTLP in regardless to showing ALL the post catless header runs. Of course one would pick the highest result but other runs even if they are 209, 210.5whp would add validity of test results.
09-05-2022, 08:43 PM | #18 |
Drives: 2022 MT Neptune GR86 Prem.
The problem is that lots of people have already tested 1st Gen catless headers on the 2nd Gen and gotten minimal if any gains. It’s hard to fathom what is different enough about this design that would lead to results like this without a tune.
09-05-2022, 09:03 PM | #19 | |
Drives: Q5 + BRZ + M796
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | x808drifter (09-06-2022) |
09-05-2022, 09:13 PM | #20 | |
--Increased runner diameter, as R^4 part of the flow equation means a small radius increase can have a huge effect on flow. --Catless increases flow. --4-1 typically does better on top end, and 4-2-1 typically does better on low end torque, and long runners tend to help flow better for better laminar flow. This header might have bigger piping than stock, catless and maybe longer primaries, but I don't know any of this, and I have no idea how the piping diameter here compares to the 1st gen, but that would likely be the biggest difference.
09-05-2022, 09:18 PM | #21 | |
But hey, there's always gotta be the exception to prove the rule, so if it holds up, good for them (and your other reasons mentioned above make sense too). |
09-05-2022, 11:10 PM | #22 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
No reason at all to throw shade at the results, these results show a lot of promise. |
09-06-2022, 12:32 AM | #23 |
Drives: 2013 frs red
I'll wait for the 10 horse intake manifold. That will require an even lower baseline
09-06-2022, 07:14 AM | #24 | |
If those numbers (that were accepted by the optimists) are correct then the new header at Max 212HP actually LOST 3HP over stock! https://www.ft86club.com/forums/showthread.php?t=148862 So which is it? They can't both be right. And you guys wonder why I question the accuracy of dyno results?
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dake (09-06-2022), x808drifter (09-06-2022) |
09-06-2022, 10:53 AM | #25 | |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
Maybe my math is wrong (the math: 228 hp rated at crank, "211" whp = 8% loss), but I'm pretty impressed by how "little" drivetrain loss there is in the stock Gen2. Maybe it's more of a possibility to see higher hp increases with "basic" upgrades |
09-06-2022, 10:59 AM | #26 | |
09-06-2022, 11:34 AM | #27 | |
Drives: '23 BRZ
And this header does not *really* add 20hp, no way no how the factory exhaust is THAT bad. Judging from the curve being nearly exactly the same as stock, I would bet real same vs. same, header might have gained a couple/few hp. Or lost that much. Last edited by ZDan; 09-06-2022 at 11:50 AM. |
The Following User Says Thank You to ZDan For This Useful Post: | DarkSunrise (09-07-2022) |
09-06-2022, 11:59 AM | #28 |
Drives: frs
Lets wait JDL autodesign to debunk this
Similar Threads | ||||
2Gen twins vs many drag racing | PulsarBeeerz | BRZ Second-Gen (2022+) -- General Topics | 10 | 01-16-2022 09:50 PM |
JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
