09-26-2022, 08:10 AM | #855 |
Drives: 2022 BRZ; 2014 BRZ
I like to run mine at 34F 36R. Think I started at 36 since that's what the car recommends in the door jam and wanted a little more out of the front in sweepers, so dropped the front a couple of psi, and decided that was enough sidewall rollover for local events. At ZMAX I'll drop it down 2 psi since that's a sealed pavement and drives differently from everywhere else I go.
09-26-2022, 08:14 AM | #856 |
Had a blast yesterday, this might have been the deepest I've gotten into third at an event. Was great fun keeping it held coming into the final turnaround. I don't run data, but I'd guess I was somewhere up around 70 mph. Conned away a 4 tenths faster run keeping it pinned into that section for longer which would have put me 2nd or 3rd PAX, but ended up 6th PAX of 95 or so.
09-26-2022, 09:38 AM | #857 | |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
What I mean by that is, while they shouldn't be used exclusively to figure out tire pressure, can't you use them to see if you're running too low? If the tire is rolling past them and onto the side wall, I'd think that would be a problem. Adjusting tire pressure to optimize what little can be adjusted on a bone stock car is something I'm still learning. |
09-26-2022, 01:51 PM | #858 | |
Drives: '13 FRS - STX
10-17-2022, 02:05 PM | #859 | |
Drives: 2022 BRZ
After struggling in a similar manner as you, I did some research and learned something that even some fast AutoX'ers don't seem to understand. The best way to get grip is to ADD pressure. You want to set them as HIGH as possible, up to the point right before the tire starts to cup. For me, this year, on the '22 BRZ in DS with 660s, that has turned out to be 35/35. Slightly off topic...my understanding on the '22 BRZ...the rear camber is non-adjustable, and so is the rear toe. Is that correct? Thanks, Mike |
10-17-2022, 02:19 PM | #860 |
Drives: '22 BRZ
Alignment adjustments are identical to first gen. Front end has camber/toe adjustment and rear end has toe adjustment.
Also, the RT660 was designed around ~35 PSI as the target hot pressure. Not surprised that's where you ended up.
10-17-2022, 02:27 PM | #861 |
Drives: 2022 BRZ
I'm just not seeing how to adjust the rear. The tie rod is not adjustable, unlike the front.
Also, one other question while I'm here...does anyone have a link to the Koni shocks people have been using? Thanks! Mike |
10-17-2022, 02:35 PM | #862 | |
Drives: 2016 Scion FRS
10-17-2022, 02:38 PM | #863 |
Drives: '22 BRZ
Just an eccentric on the inner end of the toe link.
10-17-2022, 02:41 PM | #864 |
Drives: 2022 BRZ
10-17-2022, 02:42 PM | #865 | |
Drives: 2017 BRZ PP, 2004 WRX
But wouldn't that be highly dependent on the weight of the car and drivetrain (FWD, RWD, AWD)? Also a random update: Just did possibly my final event for the year. 660's got me through to 201 runs and still have tread left. The 200 runs were from co-driving a few events - total events for the year were 24 for myself and about 160 of those runs.
10-17-2022, 03:14 PM | #866 |
Drives: 2022 BRZ
Here are a few links:
Tirerack says, for example, to DECREASE understeer, INCREASE front pressure. https://www.tirerack.com/tires/tiret....jsp?techid=58 This one is OK, a bit simplistic, but correctly also recognizes that there are many complex factors at play... https://flowracers.com/blog/how-to-s...ng-track-days/ Another example: https://www.yourdatadriven.com/how-t...yre-pressures/ I think the best article on this is here (but it is a very dry read): http://farnorthracing.com/autocross_secrets12.html I'll quote this article: "A tire will gain grip with increasing tire pressure until the internal pressure overcomes the strength of the carcass portions that keep the tire cylindrical, at which point the tire will start losing grip;" Cheers! Mike |
10-17-2022, 04:23 PM | #867 | |
Drives: 2022 BRZ
10-17-2022, 04:29 PM | #868 | |
Drives: 2022 BRZ
Mike |
Similar Threads | ||||
SCCA Solo Street Modified (SM) Discussion | whataboutbob | Tracking / Autocross / HPDE / Drifting | 61 | 07-27-2020 10:03 AM |
SCCA Solo C Street Discussion | Kido1986 | Tracking / Autocross / HPDE / Drifting | 4833 | 07-08-2020 03:52 PM |
Gen3MR2's C Street (SCCA SOLO) Progress | Gen3MR2 | Tracking / Autocross / HPDE / Drifting | 0 | 02-12-2016 01:02 PM |
2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
Henry's C Street (SCCA Solo) progression | Kido1986 | Tracking / Autocross / HPDE / Drifting | 74 | 05-04-2014 08:20 PM |
