Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-26-2019, 12:41 AM | #1 |
Drives: 2013 FR-S, 2015 TC
Rear Passenger wheel bounce during cornering
Hey All!
On hard corners (or during pavement transitions/small potholes/etc.) I am getting what feels like the rear pass wheel bouncing like mad. Sometimes it's violent enough to seem like its causing some real damage. I think the shock is blown but it's hard to tell from pushing on the car. My buddy tells me it is just the torsen letting go when going over bumps, but it happens even on smooth surfaces during moderate to hard cornering. The car has rce yellow springs that the PO Installed(unknown mileage/age) and stock shocks MY13 Frs with 75k miles Any thoughts? I am off work tomorrow so I will try to slap the go pro on the car and see if i can receate it.
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY KANSAI DORIFTO |
04-26-2019, 09:55 AM | #2 | |
Drives: 2013 WRB BRZ
The Following User Says Thank You to BigTuna For This Useful Post: | Takumidesh (04-26-2019) |
04-26-2019, 10:15 AM | #3 |
I would inspect the shocks and the rear diff + subframe bushings. Also check alignment if you haven't since buying the car.
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Takumidesh (04-26-2019) |
04-26-2019, 10:54 AM | #4 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
My wife's car had this symptom and it was a blown rear shock.
It was most noticeable when the bad shock was the inside wheel of the turn, (Ie unloaded/lightly loaded) and throttle was applied. |
The Following 4 Users Say Thank You to Twinz For This Useful Post: | DarkPira7e (04-26-2019), maslin (04-26-2019), Racecomp Engineering (04-26-2019), Takumidesh (04-26-2019) |
04-26-2019, 12:36 PM | #5 |
Exactly, like a shudder as if the whole assy is bouncing like crazy.
Sent from my Moto Z3 Play using Tapatalk
2015 TC BONE STOCK BABY KANSAI DORIFTO Last edited by Takumidesh; 04-30-2019 at 12:22 AM. Reason: fat fingered on my phone |
04-26-2019, 02:17 PM | #6 |
Senior Misanthrope
Yep, my money is on a blown damper.
The Following User Says Thank You to kch For This Useful Post: | Pat (04-29-2019) |
04-28-2019, 03:50 PM | #7 |
Drives: 2016 Subaru BRZ
You're at about the mileage that it would be a good idea to replace the struts. I bet the previous owner just zipped on the strut nut with an impact causing the rod to spin. Once you get it off you should notice fluid leaking all around the shaft and it probably won't rebound at all.
04-28-2019, 06:57 PM | #8 |
Drives: '13 FRS - STX
Do you have traction control on?
04-29-2019, 02:34 PM | #9 |
With or without traction control makes no difference.
Looks like I'm buying coilovers. Perfect excuse. Sent from my Moto Z3 Play using Tapatalk
Similar Threads | ||||
A lot of brake dust on passenger rear wheel | DTMdreaming | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 05-26-2018 03:32 AM |
Slight front wheel bounce on sharp right turn? | iceblaze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 04-09-2018 12:43 PM |
WTB Passenger Side Wheel Well Cover | Legionsk88 | Want-To-Buy Requests | 1 | 07-12-2017 07:38 AM |
Help! Slight vertical bounce with new wheels/tires | SilverTipp | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-06-2015 11:48 AM |
Buzzing from rear passenger wheel | Mattybro410 | Issues | Warranty | Recalls / TSB | 1 | 11-04-2014 09:25 AM |
