Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
06-18-2015, 01:40 PM | #15 |
Drives: '13 BRZ
What is it (theoretically) providing air to?
06-18-2015, 03:19 PM | #16 |
Drives: FRS
The duct has a guide to send air theoretically towards the intake on that side. I made the piece also extend back under the crash bar to guide air into the rad rather than up into the bumper
06-19-2015, 10:44 AM | #17 |
Drives: FRS
I like it. The duct needs to be straight. And I would go matte black. Other than that, it's awesome. Good idea.
06-19-2015, 06:06 PM | #18 |
Drives: 2015 Scion FR-S (Asphalt)
I like the idea...don't dislike the execution but not real fond of it either. I would suggest the following:
Symmetrical intakes A little more flush with the intakes Flat finish Recess the assembly a bit further back so it doesn't look like it is part of the nose but more part of the grill. Good luck! |
06-20-2015, 12:32 AM | #19 |
Drives: 2013 Scion FR-S - Argento
07-31-2017, 10:20 AM | #20 |
Drives: 2013 Scion FR-S in White
Revive this old thread! This is an awesome idea and I’m really interested in any updates!
07-31-2017, 10:28 AM | #21 |
The Gunshine State
Drives: '14 BRZ Limited
If you want a mustache, get a BRZ!
Lol kudos to the OP for this project.
Current DD: M235i |
08-02-2017, 06:23 PM | #22 |
Drives: 2016 Subaru BRZ
I am actually in the process of laying up the negative replica mould which will be modified with adding appropriate inlets. I am planning four rectangular openings spaced across the 'mustache' with proper radius on the edges for smooth air flow (Think the entrance to a venturi) and visually pleasing. After I get the mould made I will be doing the actual part layups with polyester and glass cloth, fitting n painting.
Why? , I just wanted to get rid of that obnoxious piece on the front of the car, I don't need the extra cooling or 'clean, cold air' intake.
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
08-04-2017, 04:20 AM | #23 |
Mine
Sent from my Galaxy S8+ using Tapatalk |
Similar Threads | ||||
Jay's 86 Build: Opinions Wanted! | jay_jay_lp | Member's Car Journals | 0 | 01-11-2015 04:02 AM |
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune | aaronsadventures | Member's Car Journals | 6 | 12-04-2014 02:01 AM |
custom grill similar to aston martin?? | sofrsnsokleen | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 11-08-2014 09:26 PM |
FR-S Wishlist build!! Opinions welcome!! | Spencer Strayer | Engine, Exhaust, Transmission | 4 | 01-22-2013 05:23 PM |
Rwd-boxer's backyard exhaust fix | RWD-boxer | Engine, Exhaust, Transmission | 9 | 06-11-2012 06:15 PM |
