Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-14-2012, 03:19 PM | #15 |
STi Brembos pretty much bolt on, and you can get 'em used for ~$1200 plus rotors/pads. Why the hell would anyone buy a new Brembo kit for that much?
Personally, I'll probably try to use WRX 4pot/2pot calipers because I know the Brembos will be overkill.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. Last edited by Turbowned; 04-16-2012 at 07:58 PM. |
04-14-2012, 04:04 PM | #16 |
Drives: Attitude
Holy Christ. How many times do I have to say this. IT WONT WORK (PROPERLY). I won't even repeat why, just search and figure it out for yourself.
04-14-2012, 04:37 PM | #17 |
Drives: SWP BRZ LTD
Wrx brakes aren't 4 pots either. This car comes with Wrx brakes.
04-14-2012, 05:35 PM | #18 |
Drives: Attitude
True and not true. WRX had 4/2 pots in 2006/2007. The rears wont fit at all, the fronts will bolt up but will STILL NOT FUNCTION PROPERLY.
04-16-2012, 11:55 AM | #19 |
Hmmm, well GReddy drives their car on the street with those brakes so something tells me it does work
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. Last edited by Turbowned; 04-17-2012 at 11:22 AM. |
04-16-2012, 12:31 PM | #20 |
Site Moderator
Drives: Stuff
Actually those WRX calipers (the alum 4 pots) are NOT differential bored (based on statements of those on here who own them anyways, and RCE stated that also IIRC), so you can swap L to R and R to L to get the bleeders up top.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
04-16-2012, 01:16 PM | #21 |
Drives: Attitude
Ah, well I've never owned the Nissan 4 pots. The Brembos are differential bored so the point still stands in their case.
FWIW, the Nissan 4 pots provide no thermal capacity over stock; they use the same thickness 290mm diameter rotor as the stock WRX. I've been under the impression we're getting the same 290mm rotors. In the WRX they provided a rearward bias shift, which may not be necessary in this application. |
04-16-2012, 01:36 PM | #22 | |
Site Moderator
Drives: Stuff
They will provide a little better feel and modulation, plus more even pad wear, but that's about it. Oh, and looks for those into that.
-Dave
04-16-2012, 02:23 PM | #23 |
Drives: SSM LT MT BRZ
the pad wear issue is so minimal it isn't worth discussing, staggered pistons are a cute idea that makes so little difference it will probably disappear on all but the most expensive multi pad calipers.
I make a wilwood 12.2" kit for Nissan S-chassis cars, it saves weight over the stock setup, with the wilwood FSL calipers (4pot) and 2 piece rotors (i make hats also) but the huge advantage is pad thickness and replacement cost for consumables, it is almost exclusively bought by people that want a trackable setup that has better than Z-32 upgrade performance with lower consumable cost. The biggest issue with most BBK's is 1, they are generally too big (bling factor) and 2 way too expensive both up front and down the line, example wilwood's OTS kit for s13 BBK, the kit costs~400 more than the kit I make after all parts are bought and on the car, and they use more expensive consumables with less pad thickness...they get you coming and going... |
04-16-2012, 07:45 PM | #24 |
Wait one cotton-pickin' minute!!! They drive this car on the street in this configuration... how are you saying this "won't work"?
"The brakes on the car are perhaps the easiest things to upgrade. The Brembo calipers for a 2004-2012 STI will bolt right in the front. For front rotors use the STI parts from a 2004 with the 5x100mm bolt pattern. For rear brakes use the 2008+ STI parts and drill the rotors for a 5x100 bolt pattern. The bolt pattern is the one thing we really hate about the car. 5X100mm is an unusual pattern instead of the very common 5x114.3mm. This greatly limits the number of aftermarket wheels available for the car. If someone at Scion/Toyota/Subaru is reading this, please change this before production, pretty please! A whole industry and all the fans and buyers of the car will thank you! Subaru changed so you can too!" From MotoiQ: http://www.motoiq.com/magazine_artic...cion-fr-s.aspx
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. Last edited by Turbowned; 04-16-2012 at 08:03 PM. |
04-16-2012, 08:34 PM | #25 |
Site Moderator
Drives: Stuff
Re-read our posts again.
-Dave
04-16-2012, 09:18 PM | #26 |
Drives: Attitude
You obviously didn't get it, because that MotoIQ article actually got it wrong.
04-17-2012, 11:17 AM | #27 |
Alright, fine. I emailed GReddy to ask if they could shed some light on the subject, because they're running these brakes on their Scion Racing FR-S drift car. They must be able to clarify these concerns. Personally I could give a crap less because I have no intention of putting them on my car, but no doubt a lot of people will want to do it if possible, and it would be nice to get all the facts straight.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
04-17-2012, 11:30 AM | #28 |
Rocket Surgeon
Drives: PSM GGA OMG
Those front calipers aren't STI Brembos. They have "Greddy" embossed across the outboard face, for one thing. It's hard to tell from the picture, but they don't appear to be differentially bored. And if you'll notice it has multiple bosses cast into it for bleed screws, so all they had to do to adapt it to the new platform is to drill and tap the other boss instead.
Similar Threads | ||||
Body Kits / Aero Parts | Loki2x | Cosmetic Modification (Interior/Exterior/Lighting) | 1467 | 11-15-2022 04:34 AM |
WingsofWar Aero Kit Design | WingsofWar | Cosmetic Modification (Interior/Exterior/Lighting) | 127 | 05-29-2012 07:51 PM |
BRZ added to tirerack for tire selection... | mines13 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 12-05-2011 10:19 PM |
NA engine kits? | Levi | Engine, Exhaust, Transmission | 36 | 11-17-2011 11:45 PM |
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
