Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Forced Induction
Old 05-03-2021, 10:37 AM   #4075
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
Originally Posted by Mad1723 View Post
Enough to slightly feel it, and not enough to lose sleep over. It's just like the "higher center of gravity" some people mention. You will NEVER feel it. And if you do, some professional racing teams are looking for your talents.
Sent from my Pixel 4 XL using Tapatalk
Yeah had mine now for about a year, only about a 1500 miles on it. I had a DT tune then had a tuner get a hold of it. The drag you don't feel that much. When you are hitting close to max torque just before 3k (yes it does peek a little more at higher rpm), you just don't care. It's there and if you've driven it NA enough you might notice but it's no big deal.
I disagree slightly on the weight or CG issue. I think it's a weight concentration issue more, but certainly the CG as changed because of it, especially with this SC. You feel it in high speed corning or slalom courses. I think that's why many choose a Vortech or Jackson for racing applications as it doesn't concentrate the weight or have it as high, but I know some using the EB on track too.(me) While I've removed enough weight in various areas of the car that about equal the additional weight of the SC, it's now concentrated in the front and it makes it want to understeer a little. Day to day driving no you don't notice. 120 mph high speed turns you feel it trying to break loose more and requires some suspension adjustment to settle it. Why I've always recommended upgraded coilovers with this SC. My hypermax do a pretty good job.
Piggy backing, I do think as I did a year ago the Dbox is not ideal. It's a band aid fix at best and my tuner was pretty much able to take care of the flutter. It may still have a little at the 6.5k to 7k and my tuner was totally cool with building a secondary remote MAP sensor set up if I wanted. He wasn't cool with just relocating the MAP on a single setup as he said that does affect other MAP inputs (probably temp) but a dual setup he thought would be cool. I didn't at the time but I may if I flex fuel it. It gets hot down south and running E85 would keep the block a little cooler on track, why I haven't tracked it that much. I feel sorry for B_T who just burned a hole in the block. Again daily driving, doesn't matter. Had to do over again, I might do it differently but might not. Each application has pros and cons.
AKITA is offline   Reply With Quote
The Following User Says Thank You to AKITA For This Useful Post:
CSG Mike (05-03-2021)
Old 05-04-2021, 04:22 PM   #4076
dynarun55
Drives: 2015 midnight blue limited edition
Hey guys,
I'm relatively new to the forum. I'm contemplating buying an Edelbrock SC but I'm curious about how the updated bypass valve performs now. I read a lot of threads about how the bypass valve needs to replaced regularly. Has anyone purchased an installed the newer kit with the updated actuator ? This is the only issue that is preventing from pulling the trigger on the purchase.
dynarun55 is offline   Reply With Quote
Old 05-04-2021, 04:27 PM   #4077
B T
Drives: 15 Supercharged BRZ
Originally Posted by dynarun55 View Post
Hey guys,
I haven't had to replace my updated valve, but it's honestly not that bad to do. Think I replaced it one time and then preemptively with the updated version. supercharged for 50k miles now.
B T is offline   Reply With Quote
Old 05-04-2021, 04:29 PM   #4078
dynarun55
That's good to hear. Have you installed any additions to the bolt on kit ? When did you buy your kit ?
Old 05-04-2021, 04:35 PM   #4079
B T
Thats good to hear. Have you installed any additions to the bolt on kit ? When did you buy your kit ?
Just about every bolt on you can buy and a built block now after the original failed at 45k into being supercharged. Definitely get the catch cans and an oil cooler.
Old 05-04-2021, 04:38 PM   #4080
dynarun55
For sure..
Sorry to hear about thr engine failure. Any particular reason for the failure.. Also there is this theory that the higher low end torque on the Edelbrocks and Harrops make FA20 stock engine vulnerable ? Relatively compared to a JRSC ?
Sent from my Pixel 3 using Tapatalk
Old 05-04-2021, 04:41 PM   #4081
Auto_egr
Drives: 2017 CWP BRZ w/PP
B_T you were running a smaller pulley and bad E85 when it blew right? Just curious and I hope your new block treats you well. Did you go with IAG and are they building the whole long block?
Auto_egr is offline   Reply With Quote
Old 05-04-2021, 08:32 PM   #4082
CSG Mike
CSG Mike's Avatar
Hey guys,
None seem to have failed since the major update. It's still fairly recent, but Edelbrock backs their product.
PM to order.
Old 05-04-2021, 08:33 PM   #4083
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
My Edelbrock SC is coming the 11th…I am just using it for a DD with backroad drives so keeping it in the mid 250s.
I’ll be adding an oil cooler and catch can in the next couple months, but it does not get very hot in the PNW
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is online now   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
Elliotw (05-15-2021)
Old 05-04-2021, 09:22 PM   #4084
dynarun55
PM to order.
Will do soon. Thanks for the response.
Old 05-05-2021, 09:08 AM   #4085
B T
For sure..
I wasn't doing anything but running on cruise control with a E85 when it blew. I was an hour and a half into a two hour trip at the time. Stock pulley size. Never figured out exactly what caused it. I believe the rods were weak due to some misfires from poor quality gas earlier in the week. I'm running on a stock compression IAG closed deck built block with a thicker head gasket and 2.75 pulley now.
Old 05-06-2021, 12:30 PM   #4086
dpfarr
Drives: BRZ ts
The instructions mention 50:50 coolant. What does that mean? Audi VW coolant? Toyota rated coolant?
dpfarr is offline   Reply With Quote
Old 05-06-2021, 01:01 PM   #4087
B T
They aren't picky. Use whatever you put in your radiator.
The Following User Says Thank You to B T For This Useful Post:
dpfarr (05-06-2021)
Old 05-06-2021, 02:00 PM   #4088
Glitch
Drives: 2019 86 TRD SE
I used a different color than what is in my radiator to make troubleshooting leaks easier in the future.
Glitch is offline   Reply With Quote
The Following User Says Thank You to Glitch For This Useful Post:
dpfarr (05-07-2021)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 336 10-28-2020 10:59 AM
Edelbrock E-Force Supercharger itsibarra Forced Induction 936 09-27-2016 03:51 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
