Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
05-08-2016, 03:15 AM | #29 | |
Drives: UltraMFrS
The Following User Says Thank You to turtlefeeder For This Useful Post: | zmz0305 (05-08-2016) |
05-08-2016, 10:42 AM | #30 | |
Drives: subaru brz
Good luck in the finals! |
The Following User Says Thank You to zmz0305 For This Useful Post: | Guff (05-08-2016) |
05-08-2016, 10:45 AM | #31 |
Drives: subaru brz
05-08-2016, 10:54 AM | #32 | |
Drives: subaru brz
I went through a lot of brands and had a hard time making a choice. Do you have suggestions? Ideally I would love to have most HP gain. Which brand is the best? |
05-08-2016, 04:00 PM | #33 | |
Drives: Corn Juice junkie
@the OP in regards to intakes that produce HP gains. Unless the intake is feeding some forced induction there is little to no gains to be had. |
The Following User Says Thank You to seito23 For This Useful Post: | Tcoat (05-09-2016) |
05-08-2016, 04:32 PM | #34 | |
Drives: subaru brz
05-08-2016, 05:42 PM | #35 |
I would purchase a new rubber intake hose like the Mishimoto. I just personally never liked that metered air was being used to pump sound into the cabin. especially on closed loop systems, if you notice, a lot of stock twins have very spotty tailpipes from the rich condition. Remove all the extra nonsense.
05-08-2016, 09:46 PM | #36 | |
Drives: subaru brz
05-08-2016, 09:49 PM | #37 |
Drives: whiteout, dark tint
05-08-2016, 10:14 PM | #38 | |
Now, wasn't that easy ...... humfrz |
05-09-2016, 10:10 AM | #39 | |
Drives: subaru brz
Sorry english is not my first language and I am kind of car noob here. |
05-09-2016, 10:13 AM | #40 |
Drives: subaru brz
05-09-2016, 11:41 AM | #41 | |
By "rich" they mean that the car is burning an AFR (air fuel ratio) that is heavy on the "fuel" part of the ratio. In this case, a black, sooty deposit may show up on the tail pipe outlet. Back-in-the-day, one could almost "measure" the AFR by looking at the inside of the tail pipe ....... if it was black, the engine was running rich, it was whitish, the engine was running "lean" ...... so, a light, smoke color deposit was "good". The AFR could be changed by "adjusting" the carburetor(s) or the engine timing. Today, I have no idea how the ECU (Engine Control Unit) alters the AFR. However, someone in the know, will have to explain that to you ...... humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | seito23 (05-09-2016) |
05-09-2016, 11:55 AM | #42 |
Well yes ....... but you still have "fun" with a oiled drop in (if you are old).
find and purchase the correct filter find the air box figure out how to open it up unpackage the new filter anguish over if it has enough oil or too much oil now, which way does it go in ....... frontwards/backwards .... upside down/right side up why won't the air box cover close .... worry that it has too much oil and it will gum up the air flow sensor thing not enough oil and it will let in dirt and the engine will grind itself up take it for a drive YES! AT least 3 more HP and 2 ft lbs of torque, measures on your butt dyno ......... All for $40.00 and 15 minutes of labor .......... Time for a nap! humfrz |
Tags |
noise, whistle |
Similar Threads | ||||
Road noise? Tread Noise? | zERoTu | Issues | Warranty | Recalls / TSB | 21 | 10-07-2020 10:21 PM |
whistle noise in 6th? | Lydin | Engine, Exhaust, Transmission | 43 | 10-28-2016 02:45 PM |
Engine whistle between 2-2.5K RPM | ShackontheTarget | Issues | Warranty | Recalls / TSB | 2 | 05-15-2015 02:25 PM |
Turbo Whistle v. Blower Whine | SupraLove | Forced Induction | 34 | 11-21-2012 08:56 PM |
