12-23-2020, 11:23 AM | #71 | |
Drives: Q5 + BRZ + M796
12-23-2020, 11:40 AM | #72 | |
That Guy
Drives: 2013 asphalt FRS MT
The Following 2 Users Say Thank You to Calum For This Useful Post: | CSG Mike (12-23-2020), x808drifter (12-24-2020) |
12-23-2020, 01:17 PM | #73 | |
I can certainly make observed boost higher, but that would come at a power loss. Try blowing as hard as you can through a coffee stirrer, vs a mcdonalds straw, vs a boba straw. Note the inverse correlation between boost (how hard youre blowing through the straw) vs flow (how much air is going through the straw). This is one lungpower of boost/flow through various straws. |
The Following User Says Thank You to CSG Mike For This Useful Post: | x808drifter (12-24-2020) |
12-23-2020, 01:32 PM | #74 | |
This guy has a EJ205 WRX and the same turbo at 20 psi. https://forums.nasioc.com/forums/sho....php?t=2465521 https://www.ft86club.com/forums/show...&postcount=107 https://www.ft86club.com/forums/showthread.php?t=68154 Not really sure why it says wastegate then he is saying his wastegate is always closed. I'm just confused.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Calum (12-23-2020) |
12-23-2020, 02:06 PM | #75 |
Max boost of a turbo is at zero flow, Max flow of a turbo is at zero boost. Nether of these numbers are going to tell you how a turbo will interact with the engine in the middle.
This feels like Groundhog Day! |
The Following User Says Thank You to Grady For This Useful Post: | CSG Mike (12-23-2020) |
12-23-2020, 02:43 PM | #76 | ||||
A wastegate that is permanently closed is one that never opens, so it never allows exhaust gases to bypass the turbo's exhaust turbine. As such is the case, the turbo is free to flow as much air as it can, which will be a byproduct of how fast an engine can spin the exhaust turbine that will spin the compressor turbine, and how much air the compressor turbine can grab. That is a limit of the size of the fins, the speed of the fins and any offloading limits, so the size of the housing. Considering the above, it sounds like you are saying the turbo is so small that even without a wastegate the turbo will not overboost on your setup, and what happens is boost rises fast to 7psi, but then it rises more slowly where it hits its limit at 10.5 psi before hitting redline or falling. Ok, so if that is the case, and we know other 2.0L platforms and 86's hit higher boost, while still using their wastegate to not overboost, what are you doing to keep your pressure down? The only answer I can think of is IATs being dramatically lower, but I don't think a giant FMIC would do it. I could be wrong. Maybe you misspoke, and your wastegate is opening at a predetermined boost level of 7psi, which is where your wastegate spring is at, but you have an EBC tuned to bleed off boost from the vacuum line running to the wastegate, so you can slowly ramp up boost to a peak of 10.5 psi. I'm curious. I would love to see someone remove the pressure line going from the turbo's compressor housing to the wastegate actuator, so the wastegate never opens and run this turbo to redline.
12-23-2020, 02:47 PM | #77 |
Drives: brz 2017 hksv2
and how did csg mike make the engine flow so super good that a t518z turbine at maximum with wg closed all the time makes only 0.72bar of boost? extreme amount of valve overlap blowing everything out of the exhaust? modified heads?
The Following 2 Users Say Thank You to tomm.brz For This Useful Post: | Calum (12-23-2020), Irace86.2.0 (12-23-2020) |
12-23-2020, 02:56 PM | #78 |
Ancient Chinese Secret possibly?
12-23-2020, 02:58 PM | #79 |
義理チョコ
This is THE way to do it.
12-23-2020, 03:05 PM | #80 |
Like the opposite is possible. Match a large turbo to a proportionally small wastegate, and there can be boost creep. This is when the wastegate opens, but the engine still produces more air than the wastegate can reject, so as rpms rise, exhaust gases eventually spin the turbine faster.
Similarly, someone could remove/leave the wastegate open. With a wide open wastegate bleeding off only a fraction of the exhaust, the exhaust could eventually generate enough flow to spin the turbine and boost could rise. It would likely have a low boost ceiling. I don't know anyone who does this. I also don't know the efficiency of said setup.
12-23-2020, 03:07 PM | #81 |
Yes, did that, AVO turbo with stock exhaust. Boost would build to just under 10psi around 6k rpm then drop to around 7psi at red line. Yes there was more airflow at 7psi then there was at 10.
12-23-2020, 03:12 PM | #82 |
I don't know if he was saying he modified the hot side or if he is saying the hot side is naturally large. It doesn't look large:
12-23-2020, 03:23 PM | #83 | |
Uhhh, really?
12-23-2020, 03:27 PM | #84 |
義理チョコ
Basically, the compressor is geared low for the displacement so it becomes the limiting factor in the system. It spools later in the game but when it does, it's super responsive and is literally unable to overspeed the compressor. The combination is tuned for play above the vvt crossover speed.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Irace86.2.0 (12-24-2020) |
Similar Threads | ||||
WTB Turbocharged BRZ | scoobyy | Want-To-Buy Requests | 0 | 08-28-2016 01:02 PM |
TWINCHARGED (Supercharged & Turbocharged) Widebody "WTF-86" 86/FRS *MASSIVE* build :D | WTF | Member's Car Journals | 224 | 08-18-2016 09:39 PM |
Looking for a turbocharged FRS | malandrin2011 | Cars for Sale/Trade | 16 | 03-21-2015 02:49 PM |
Supercharged GT 86/FR-S/86 vs. Turbocharged BRZ | switchlanez | Scion FR-S / Toyota 86 GT86 General Forum | 61 | 12-20-2011 11:16 AM |
