10-02-2020, 09:53 AM | #1 |
Carbon Trunk Swap?
Picked up a VIS carbon trunk that has a garnish not meant to accommodate the factory backup camera, any chance someone out there has the opposite problem and wants to trade?
10-02-2020, 03:53 PM | #2 |
You could mod it to fit the camera. It’s a small piece.
10-02-2020, 04:42 PM | #3 |
10-03-2020, 10:32 AM | #4 |
Drives: jrsc_brz
dremeling carbon is super easy, ive done a shit load of it fitting a carbon fiber belly pan onto a s1000rr. its not nearly as bad as you think its going to be, doesnt fray, doesnt crack, just cut a little square hole to fit the camera. i was petrified before trimming it too, but its underwhelming actually doing it
the chance of someone trading you a carbon fender garnish with a camera cutout for a carbon fender garnish without a camera cutout is non existent.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
The Following User Says Thank You to HaXx For This Useful Post: | jordan7831 (10-05-2020) |
10-03-2020, 12:55 PM | #5 |
Rust bucket enthusiast
We did this on my friend's CF trunk. It's not as brittle as you're imagining
10-05-2020, 09:33 AM | #6 | |
Appreciate the info gents, any advice on doing it? Tape it first? Just use a small drill bit to start? |
10-05-2020, 10:49 AM | #7 | |
Drives: jrsc_brz
10-05-2020, 11:23 AM | #8 |
[QUOTE=HaXx;3372987]taping a border around the square you want to cut out would be a good start, then use this attachment to cut one side of the square at a time. then test fit the camera and trim a little as needed
Ok, and so i'd be safer just starting with the cutting wheel as opposed to drilling a bunch of holes around the border then 'punching' it out? Concern is that it'll be a really small hole and using a wheel like that might lead to it being bigger than needed. |
10-05-2020, 09:42 PM | #9 | |
ProCrastinationConsultant
when making cutout's, i usually alternate between a fiber-reinforced cutoff wheel for extremely rough shaping, and these for the more precise shaping: https://www.dremel.com/en_US/product...93-carving-bit https://www.dremel.com/en_US/product...94-carving-bit when getting within 1/4" of where it needs to be, i'll shift from power tools to hand tools like sandpaper/files to get the final depth. i've found it's much easier to control without going over to easily. and test fit often!
Similar Threads | ||||
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? | 07stealth350z | DIY (Do-It-Yourself) Guides | 8 | 08-27-2020 03:27 PM |
Carbon Fiber Trunk Swap | WhiteTigerX125 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-20-2018 01:52 PM |
Trunk Swap (My trunk w/ Limited spoiler to non wing) SWP | Kuujo | Southern California | 4 | 09-18-2015 01:34 PM |
does anyone want to swap his/her wingless trunk with my winged trunk ? (hot lava) | hendryhendry | Southern California | 9 | 06-03-2013 05:47 PM |
WTB/WTT : black brz trunk spoiler or trunk swap | ph0en1xtk | Exterior Parts (Aero, Lighting, Etc.) | 1 | 03-19-2013 11:03 AM |
