08-31-2022, 10:25 PM | #4229 |
Drives: 2013 FR-S Series 10
I'd just do the SS1s. Bite the bullet and do it once and do it right.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
The Following User Says Thank You to Decep For This Useful Post: | BlueWhelan (09-01-2022) |
09-01-2022, 07:55 AM | #4230 |
Drives: Transit Campervan / Turbo GT86
I've been reading the old stories about the Whiteline Com C strut mounts that were clunking. It's been almost 10 years, did they ever sort them out?
L.E. Probably no, checked their website, com c's are not listed as compatible with brz/86... Last edited by tekno; 09-01-2022 at 08:43 AM. |
09-01-2022, 09:53 PM | #4231 | |
Drives: Brz
Would stock wheels, stock height/suspension, 215/45R17’s, a tire like an RS4, camber bolts(ordered), rear LCAs (ordered) and alignment be overwhelming the stock dampers/springs? Or making for large amounts of body roll? |
09-01-2022, 10:25 PM | #4232 | |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
You won’t overwhelm the stock suspension with those tires and some camber. The cars gonna come alive compared to OEM. To an extent, you want the body roll. It’s another medium of communication. I ran standard ride height up until this year with much stickier rubber than RS4s, and was pretty close to higher class cars with just a good alignment and tires. Tons of grip and stroke (roll), but the car felt amazing in all conditions, at any speed, under any load. Granted…this was with slightly uprated sway bars and suspension from a TS. Sent from my iPhone using Tapatalk |
09-01-2022, 10:27 PM | #4233 | |
Just the Pedders units instead. Ran those hard for 2 years and had zero issues. Some extra caster was an added bonus. Sent from my iPhone using Tapatalk |
09-05-2022, 03:20 PM | #4234 | |
Drives: Brz
09-06-2022, 09:57 AM | #4235 |
Anti stance.
I just went from tS dampers and TRD lowering springs with TRD sway bars and RE-71Rs/R-S4s to RCE Tarmac 2, TRD sway bars, and R-S4, and the biggest difference for me is the low speed damping control. There is a series of undulations in a high speed corner that I'm quite intimate with, that would upset the rear of the car on the stock suspension (dampers, springs, bars) and the tS setup mentioned above, that would detract from the overall confidence I had in the car. The RCEs have tamed these bumps right up and really let the tires do their job through this corner without the rear end feeling like it's rolling over ocean swells.
The Following 3 Users Say Thank You to Tokay444 For This Useful Post: |
09-08-2022, 04:52 PM | #4236 | |
Drives: #337 2017 Toyota 86
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
The Following User Says Thank You to Lincoln Logs For This Useful Post: | Racecomp Engineering (09-18-2022) |
09-18-2022, 06:38 AM | #4237 |
Drives: 2016 Subaru BRZ WRB
That's another vote for the SS1 then. Time to save up!
Sent from my Pixel 6a using Tapatalk |
The Following User Says Thank You to RM_2 For This Useful Post: | Racecomp Engineering (09-18-2022) |
09-20-2022, 09:59 PM | #4238 |
Mine were great and after 35-40k miles felt about the same as when i first put them on. Maybe a bit rougher. But the top hats i only heard once or twice when hitting sharp bumps at too high of speed. It's kind of a metallic noise rather than a big thump. Definitely would use KW based product again especially one custom tuned for the platform.
The Following User Says Thank You to Decep For This Useful Post: | Racecomp Engineering (09-21-2022) |
09-28-2022, 02:42 AM | #4239 |
FR-S driver
Drives: ULTRAMARINE Scion FR-S
All new suspension, PLEASE HELP
Hey guys, need some help, let me start off with the mods entailed in this most recent update.
KW v3 vorshlag top hats for the front spl outer tie rod end megan inner tie rod ends spl sway bar end links front spl toe arms spl trailing arms Now, prior to the install I had RSR isport moto spec coils that I had installed myself and had Raceline corner balanced the car. The reason for the change was that the RSR coils were 10 years old and wanted to upgrade to kw, all the other parts were added on to refresh the suspension. I went ahead and installed all the parts and due to it being my first time trying to adjust ride height I just went with what I thought was closest to stock height, doing so made me have to adjust a few things. My sway bar end links are fully adjustable and I have no clue what I should put the length to, partly because what was on there prior which was the perrin solid end links. I attempted to align the car and the rear was able to be put within spec, but the fronts camber is outside of its tolerances, too negative. To stop myself from rambling on I'll list my questions and hope that I can get some advice. 1. Would adjusting the swaybar end link be the issue with the camber being out, or is it just that the ride height is the issue. 2. I do not want the car at stock ride height, after lowering to desired height, what camber specs should I be looking to get. I had it at -1.0 in the front and -1.6 in the rear.(reference, I daily the car and have had it for over 10 years.) 3. I live in Ventura county and have called multiple shops and none of them corner balance, I know that Counterspace garage might be able to help, but they are 70 miles away from me. Anyone know of anybody local that is good. 4. Should I just get it towed to a specialty shop and have them tune it, I just installed the Potenza re-71rs and dont want them to burn out. Any input would be appreciated.
mod on
09-28-2022, 09:21 AM | #4240 | |
2. How low are you planning on going? Is the car strictly a daily driver or is there track/autox time? I'm confused why you went with the aftermarket inner and outer tie rods? 3. Corner balancing is nice, not required for a daily driver IMO. 4. A specialty shop is a good idea. You have a lot of adjustment and specialty parts...a suspension tuner is a good call. With those parts and those tires, I'd expect a more aggressive alignment. -1.0 is nothing and is leaving a lot on the table with those tires. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | ric342 (09-29-2022) |
09-28-2022, 11:32 AM | #4241 |
Drives: what
Hey RCE when are the 22 GR/BRZ yellow springs coming out? im ready to buy
09-29-2022, 12:48 AM | #4242 | |
FR-S driver
2. The car is daily driven with some track and autox, I went with aftermarket tie rods after reading am article that Moto miwa posted talking about how after 5 years regardless of miles a person should swap them out to keep the steering wheel feeling tight. With that said I opted to go with an upgrade instead of keeping the oe. 3. Ya I know, but I wanna do it right. 4. I have the car at Chewerks right now, hopefully they get it back to me in better shape. thanks for the quick response btw. Any input on the end link length, was looking everywhere for info and found nothing.
mod on
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
