GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
01-20-2022, 01:19 AM | #1 | |
Drives: 2022 Halo White GR86
Coilovers from Gen1 Don't fit on GR86?
I contacted KW directly to ask if they have anything for the GR86 and this is the response I received:
01-20-2022, 10:38 AM | #2 |
1st gen coilovers do indeed fit. KW has to be concerned about European TUV certification so they have a few more hoops to jump through.
We are partnering with KW to develop a couple new parts for the 1st and 2nd gen concurrently, but our existing RCE SS1 and RCE Tarmac 2 coilovers (made by KW) work great on the new cars. We've got a bunch of them out there already. There are some minor differences in the rear in terms of geometry...but overall weight and weight distribution is extremely close. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | timurrrr (01-20-2022) |
01-20-2022, 10:59 AM | #3 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Edit: nevermind. i'm dumb haha
01-20-2022, 11:35 AM | #4 |
Drives: 2015 Scion FRS Release Series 1.0
Andrew, since you mentioned you are developing a couple new parts for the 1st and 2nd gen concurrently,
1. When do you think you will have coilovers for for the GR86? 2. If the current RCE SS1s fit, wheat would you change/tweak to make the new one for 2022? Thanks Omer |
01-20-2022, 12:04 PM | #5 | |
TRACKBREAD
Do the SS1 fit with the stock front top hats? If so, can you comment on the OEM top hat vs the camber plate regarding NVH? I know its very subjective but Im worried about how harsh the solid camber plate is. I had ST XTAs on my E46 and those were a bit harsh for daily driving. |
01-20-2022, 12:06 PM | #6 | |
Drives: '22 BRZ Limited 6MT
01-20-2022, 01:40 PM | #7 | ||
Drives: 2022 GR86
Measured in mm's, the mount was moved by 10 mm. Quote:
The angle between the damper and the arm has changed slightly, as well as the leverage, changing the motion ratio; but I don't see what it has to do with camber. Camber depends only on the distances between extreme ends of the arms, not anything in the middle. |
01-20-2022, 02:14 PM | #8 | |
01-20-2022, 02:18 PM | #9 | |||
I had a feeling that would get a lot of questions!
2. No change. Maybe add a click or 2 more damping in the rear if at the track. To be clear, the new parts we are developing are in addition to our existing lineup and will be for both 1st and 2nd gen. They are not replacing the SS1s or Tarmac 2s. Quote:
We aren't planning any updates to SS1s. - Andrew |
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
01-20-2022, 02:24 PM | #10 |
I'm planning on posting up some math stuff in another thread talking about some of the rear changes, which are minor but sort of interesting. Lots going on here these days though!
- Andrew |
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post: | bcj (01-20-2022), dsc_pat (01-20-2022), finch1750 (01-20-2022), Stonehorsw (01-20-2022), whataboutbob (01-20-2022), Yoshoobaroo (01-20-2022) |
01-20-2022, 04:19 PM | #11 |
Drives: 2022 BRZ, Red
That would be greatly appreciated. Finally getting around to understanding suspension dynamics and am trying to apply it with the new generation if I can.
The Following 2 Users Say Thank You to Brock H. For This Useful Post: | Racecomp Engineering (01-20-2022), timurrrr (01-20-2022) |
01-20-2022, 10:31 PM | #12 | |
01-21-2022, 04:45 PM | #13 |
We've been working with KW since 2006, starting with the Subaru STI platform. KW is awesome...they make a lot of very good parts for a lot of applications. We specialize in Subarus and have our own goals with our parts. Working with KW gives us access to a great platform to build from and resources to make cool stuff.
So our Tarmac 2s are based on KW Clubsport 2 ways (not V3s, which are quite a bit softer). The valving and spring rates are customized to our specs and that's based on our testing and experience. This means a firmer front spring for our T2s and overall a little more track focused valving. We do not include camber plates, but we can add them on as an option. Our T2s have a lifetime warranty vs 90 day for the KW clubsport line. Our SS1s are similar to the ST XTA coilover and are our interpretation of a "road & track" type coilover. Single damping adjustable (T2s are 2 way) with an adjustment range that is actually usable. Our spring rates are actually a little softer in the rear than the XTAs, as we find that makes a noticeable difference as to how these cars ride on the street. So these are meant to be a daily driveable coilover (which I actually do on my own 1st gen) that is still up for track time. We like KW because they tend to have a lot of travel, great build quality, and they do a lot of the little fitment details really well. - Andrew |
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
Similar Threads | ||||
GR86 on track | FlyingJett | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 5 | 01-16-2022 08:56 PM |
Why BRZ Over GR86? | Lelandjt | BRZ Second-Gen (2022+) -- General Topics | 45 | 12-26-2021 08:41 AM |
GR86 PCD | teppey | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 23 | 07-29-2021 11:12 PM |
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 37 | 07-18-2021 03:38 PM |
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 12:09 PM |
