Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 07-20-2022, 08:05 PM   #449
jongers
Drives: 19 86, 22 BRZ
Originally Posted by OkieSnuffBox View Post
How much camber? Shave the rear fender?
Light shave on the rear fender, didn't cut any metal. Camber is around ~-2 to -2.5 atm.
jongers is offline   Reply With Quote
Old 07-21-2022, 11:40 AM   #450
OkieSnuffBox
Drives: '23 BRZ Limited
If you get a chance, could you share some pics?
I know there are a lot of us that want to get as much tire/wheel under the car as we can (because it looks awesome aside from the cornering benefits) with as little modification as possible.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 07-29-2022, 05:37 PM   #451
OkieSnuffBox
Question for ya. I've seen a few guys saying they running 18x9.5 ET45 with 245/35s and not having to make any mods to the rear fender.
Do you think if yours were +45 instead of +40 you would have still had to shave the fender.
Also what rates are you running? My coils are 7k/8k
Old 08-02-2022, 06:43 PM   #452
keonigt
Drives: 2022 BRZ
I'm currently looking at 18x8.5 +45 offset. Will these fit on stock suspension on a 2022 BRZ?
I've been getting different answers that less aggressive offsets will hit the strut/spacer. Please advise.
keonigt is offline   Reply With Quote
Old 08-03-2022, 03:19 AM   #453
bradsm87
Drives: It has 4 wheels
Yep it'll be completely fine presuming you'll be running 225/40, 235/40 or 235/35 tyres.
bradsm87 is offline   Reply With Quote
Old 08-03-2022, 09:50 PM   #454
Stigmaru
Stigmaru's Avatar
Drives: 2022 Halo White GR86
Any damage like 86 Speed received running a similar config? Seems even if you clear the fender, the inner wall gets hammered.
Stigmaru is offline   Reply With Quote
The Following User Says Thank You to Stigmaru For This Useful Post:
Wally86 (09-01-2022)
Old 08-07-2022, 04:04 PM   #455
jongers
Haven't had a chance to take my wheels off - I'll try to get a picture next weekend since I need to work on some things.
I've read that people are running 9.5 +45 w/ 245/35 without issues as well, but I can't really answer that for you as I had trimmed my rear fenders before test-fitting my wheels after finding posts on jp twitter.
My current coils are 8k front/10k rear.
The Following User Says Thank You to jongers For This Useful Post:
OkieSnuffBox (08-07-2022)
Old 08-07-2022, 04:40 PM   #456
Powersfrs
Drives: Frs
I just fitted rt615k+ 265 35 18 on a 18 9.5 +45….yup lots of rubbing. Lots of modifications to the back fenders. I added a 5 mm spacer to the front but still rub when full lock. Thanks to a dremel and lots of patience I managed to remedy the back with no more rubbing. The new grip is awesome! I’ll probably add a 7mm spacer up front and see if that fixes the rubbing. I previously had 255 ps4s with a 10mm pacer up front with no rubbing.
Ridiculous!
Powersfrs is offline   Reply With Quote
Old 08-07-2022, 06:00 PM   #457
OkieSnuffBox
Thanks for the info!
I'm just having a really hard time deciding on what wheels to buy.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
jongers (08-07-2022)
Old 08-07-2022, 10:41 PM   #458
mycrors7
mycrors7's Avatar
Drives: zd8 brz
I have Coilovers on the way and will be test fitting 18x10 +40 with a 255/35 once they are installed. I’ll keep this thread updated on how it goes/what’s required
I’ve managed to fit some pretty aggressive wheels and tires on other platforms before and this brz will no be exception
mycrors7 is offline   Reply With Quote
The Following User Says Thank You to mycrors7 For This Useful Post:
Wally86 (08-08-2022)
Old 08-31-2022, 09:08 PM   #459
Clott
Clott's Avatar
Drives: 2013 Raven FRS(Sold): Fiesta ST
Currently rocking some 18x8.5 +43 TC105's. Think I'm going to pull the trigger on some 245/35 tires and pray I don't rub. I should be good correct? Currently rocking -2.5 degrees of camber in the rear and almost the same in the front.
Clott is offline   Reply With Quote
Old 09-01-2022, 07:28 AM   #460
Petah78
Drives: 2022 BRZ sport-tech
I have the same wheel, though they are not mounted yet, and from my readings, i am pretty sure they will clear with a 245 without issues. In fact, pretty sure they will clear with just natural rear camber.
There is also this thread that have some pics of the exact setup, though he is running a 225 but it looks like there is plenty of room: https://www*********/threads/simple-...an-build.2847/ Replace ** with GR86 . ORG
Start @ 1:00.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
The Following User Says Thank You to Petah78 For This Useful Post:
Clott (09-01-2022)
Old 09-01-2022, 01:30 PM   #461
OkieSnuffBox
According to the 2022+ Confirmed fitment group 18x9.5 ET40-45 will fit with a 245/35.
Your 8.5 shouldn't be a problem at all with that size.
Old 09-01-2022, 01:36 PM   #462
Petah78
Are you sure about this? I think the referenced 86Speed GR (video above) had mentioned that exact spec which require shaving of the rear fender. There are many documented cases where 17x9, +45 is already a VERY tight fit. 17x9.5, +40 is another 11mm poke from that.
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
