#4313 |
Drives: 20' GT TRD
16 inch winters for 2020 86GT TRD package
Hi folks - super new here - tried to poke around but can not find answer..
Is there a 16inch setup for TRD package 86? Or if not - what is the skinniest rim in 17" I can fit? thanks a bunch! |
#4314 | |
Drives: 2015 BRZ
https://www.ft86club.com/forums/showthread.php?t=113691 https://www.ft86club.com/forums/showthread.php?t=62320 |
#4315 |
Drives: '16 BRZ
I'm planning to get 18x8 american racing rims particularly the Torq Thrust. It has +41 offset. Will they sit flush on my '16 BRZ? Also, what's the max tire size?
#4316 | |
Drives: 2015 BRZ
The Following User Says Thank You to Vital For This Useful Post: | wil5bart (10-12-2020) |
#4318 |
Drives: Scion FRS 2013
I'm sitting here right now in a car shop that has accidentally broken something small on my car dash during a detail. They offered me a 50% off discount on Blizzak tires, I can order whatever model I want if they don't have it in stock.
But, they do have it 4 WS80 215/55R17 tires here they can install now. Will these actually fit? I'm trying to get a confirming second opinion before I order anything. |
#4319 | |
Drives: 2015 BRZ
#4320 | |
Drives: 2017 Toyota 86
I'll also say the WS series isn't actually my top pick for Cleveland anymore. I run a set on the Matrix (So ~100WHP on a really good day.) and the spring temperature flips really eat up the rubber when it gets warm for a few days then dumps back to 30f for a week. Two years in and one pair is almost through the upper 50% of tread with the really soft rubber, and the other pair will probably be gone by the end of the winter. If you haven't jumped see if you can get some WS90s or the newer X-Ice Snows. I have some X-Ice 3s for the 86 and they're doing great after 3 seasons. They're great through the snow storms and don't get eaten up as much on dry pavement. |
#4321 |
Drives: 2014 GT86
anticubus: properly stored tire degrades little. I'd expect not more then eg. 10%/3-5 years, worsening for modern tire in storage warehause. It's when it in actual use, "clock really ticking for it", as rubber wears down, goes through heat cycles, some possible additives dissipate, roadsalt and other road chemistry and so on .. and if for some tires last even past 3 years of real use ..
So imho it's safe enough to get upto 3 years old tires, especially if they come with some good deal that more then offsets slight potential degradation. |
#4322 |
Drives: PP WRB BRZ
Will TE37SL 17x9.5+45 wrapped in 255/40 RE71Rs fit without rubbing? I’m currently lowered about 1” on Ohlins with SPL RLCAs.
#4323 |
Drives: 2015 BRZ
Yes with coilovers you should be fine. Keep in mind that every tire manufacturer have different tolerances so even if they are the same size tires some may be wider or narrower compared to a different manufacturer.
#4324 |
Drives: 2016 Scion FRS Halo
#4325 |
Drives: PP WRB BRZ
#4326 |
Drives: 2015 BRZ
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
