Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
#15 | |
The Dictater
Drives: '13 Red Scion FRS
Just to be clear TC: Cuts throttle when rear slip detected VSC: Operates brakes in order to keep vehicle pointed in direction of travel ABS: Modulates brakes when wheels lock up under braking. 6. So by "jerk to the left", are you saying that the steering wheel tries to pull out of your hand to the left when making left turns, correct? If TC is on, throttle is cut simultaneously. Does ABS engage as well? 7. Was this happening when you bought the car and didn't notice, or did this start happening after you bought the car? 8. Any sounds? |
#16 | |
Drives: 2013 Scion Fr-s
6. Yeah it tries pulling to the left suddenly TC cuts throttle and VSC, ABS engages to keep the car from totally pulling to the left 7. I never noticed it when I test drove twice, it happened about a week later I live in a somewhat hilly area but they re-did the roads not too long ago where I live, so smooth roads. 8. The only sounds I hear I believe is the VSC trying to keep the car strait and today I noticed a like pop like sound when turning so I'm guessing it has to be some type of joint |
#17 | |
The Dictater
#18 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
Bad alignment.
Happened to me after I replaced my rear LCAs -- Didn't really feel it under 20mph, but driving the 10 miles to my alignment shop was the most terrifying experience I've had on the road, as the BRZ would yank left every few seconds over 50 mph. Traction control would go haywire when navigating a mild righthand sweeper. Everything was perfect after getting rid of the INCH of TOE in the rear. ![]()
The Following User Says Thank You to dhuang For This Useful Post: | Spuds (09-06-2019) |
#19 |
Drives: Track preped NA FRS
You have toe-out in the rear. Or a bushing so bad that toe is changing on the fly depending on suspension loads, thats all there is to it I think.
#20 |
Noodleking
Drives: 2013 Firestorm FRS
My wife's is doing this. Her's is a 2018 model BRZ and everything basically describes her symptoms. I had an alignment done, which was helpful, but still didn't get rid of the sudden jerk left at anything above 30mph while turning left. Higher speeds are hella scary. Seems like when there is a bump too, the car wants to jump left.
From what i can tell, everything looks normal up front (but then again, I'm no suspension guru). The craziest part is that one of the bolts that was holding the knuckle to the shock was gone (so replaced that and took a test drive, and nothing changed, except a clunk is now gone hahaahha). So yeah, kinda scary crap. Any other thoughts on what bushing or where to check certain things? I feel like it totally happens when the car's weight shifts to that corner on a left turn-- then it dives.
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
#21 |
Drives: 2013 FR-S Series 10
Post the alignment ^
And did you get the alignment before or after you replaced the bolt?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
The Following User Says Thank You to Decep For This Useful Post: | Project N64 (09-17-2020) |
Tags |
frs steering help issue |
Car jerks hard after I push the gas | bryansuriel3 | Issues | Warranty | Recalls / TSB | 2 | 05-27-2019 12:50 PM |
car jerks to right on deceleration | ikeryder13 | Issues | Warranty | Recalls / TSB | 25 | 02-15-2016 03:00 PM |
Car jerks when shift from neutral to 1st | Vincent Nguyen | Engine, Exhaust, Transmission | 26 | 01-22-2016 08:05 AM |
Jerks | phobos512 | Mid-Atlantic | 18 | 05-17-2014 11:09 AM |
BMW drivers really are jerks...lol | Lonewolf | Other Vehicles & General Automotive Discussions | 35 | 08-25-2013 12:12 PM |
