11-23-2013, 02:52 PM | #2591 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Monday.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
11-23-2013, 02:53 PM | #2592 |
11-23-2013, 02:59 PM | #2593 |
Drives: Challenger R/T, CRX SI,
^^ What he said. I was also talking to Jpit about sharing any of his times. I know you've shared just about everything you can fenton.
11-23-2013, 04:48 PM | #2594 |
Drives: WR Blue BRZ, 240Z
Don't be tempted to add features that control rpm with throttle such as Flat Foot Shifting, Launch Control and a Soft Limiter. These features rapidly open and close the throttle plate to maintain or control rpm - while your ESC is at full rpm making full boost. Since we don't have any type of bypass there is potential of damage to the compressor/motor shaft. Not that this has happened to anyone and it's unlikely to happen at 4 psi, but how much experimentation do you want to do? These features that rapidly open/close the throttle plate are something that is best tested on a test fixture rather then your vehicle.
If you can get auto-blip - do add that. It really reduces the workload approaching a fast corner when a downshift is required.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
11-23-2013, 05:16 PM | #2595 | |
11-23-2013, 05:28 PM | #2596 |
I agree...I'm a heal-n-toe shifter since 1979...but auto-blip flat out rocks.
11-23-2013, 05:48 PM | #2597 |
Been practicing heal/toe. Not doing so hot... Any suggestions?
11-23-2013, 06:01 PM | #2598 |
Yeah, think of it more as heal and SMALL toe(s). In reality it's the top right side of your foot that you want on the throttle. Your foot should be tilted about 30 degrees to the right from vertical. Once you get the right coverage, the "feel" that you'll have to learn is how to blip the throttle without adding pressure to the brake pedal.
The other technique that I use quite a bit is clutchless shifting. Once you get the feel for it, it's as easy to down shift as up shift. As I think about it...I probably use this technique more then heal-n-toe. Since this is off-topic, feel free to ask for more details via PM.
The Following User Says Thank You to Gary in NJ For This Useful Post: | Sojhinn (11-23-2013) |
11-23-2013, 06:07 PM | #2599 | |
Drives: 2013 FRS
Just my 2c, Shiv ps. See you Monday Sojhinn! |
11-25-2013, 12:53 PM | #2600 |
11-25-2013, 12:55 PM | #2601 |
Lol just got here. Waiting for place to open. I will be updating as we go.
The Following User Says Thank You to Sojhinn For This Useful Post: | Robert@Openflash (11-25-2013) |
11-25-2013, 12:55 PM | #2602 |
What header you talking about?
11-25-2013, 12:58 PM | #2603 |
11-25-2013, 12:59 PM | #2604 |
Reading about it now. Thanks for the heads up.
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
