09-17-2013, 05:05 PM | #1863 | |
Start with post number one. Dyno Numbers do not lie, it is possible. This isn't you typical eBay crap, it pulls over 3000 watts and about 200amps peak Its treated like nos where you only use it at wot Sent from my HTC One using Tapatalk 4 |
The Following User Says Thank You to fenton For This Useful Post: | DAEMANO (09-17-2013) |
09-17-2013, 05:08 PM | #1864 | |
At sea level the HP you make is what you put to the ground. At altitude the HP you make on the dyno is corrected. When I left the dyno in uncorrected mode I made 150hp stock and 180 boosted Sent from my HTC One using Tapatalk 4 |
09-17-2013, 05:25 PM | #1865 | |
09-17-2013, 06:02 PM | #1866 | |
Drives: Raven FR-S
Keep in mind the intake temps started to run hot during the session prior to the last run. Prior to the break 10+ runs were completed. With that said, the chart posted I believe reflects the last after about a 1 hour break with no prior runs to warm the batteries up. Additionally, the outdoor temp during the session was between 85-90 F. Additionally after the session I installed the aux battery charger and noticed I had some light corrosion around the ESC batteries. I do not think it really mattered, but just a note. Personally, I think the car is even faster since the tune has adapted to my driving. Additionally since things have cooled down into the mid-70's in the NW, the unit is really kicking some ass! Which leads me to believe the optimal intake temp to get the most of the unit is roughly between 65 and 80 degrees. I have notice using the torque app the intake temps when moving tend to run approximately 10 to 15 degrees warmer. Once the unit is engage the air measured in via the intake and external thermometers are almost identical. Some here is the million dollar question: What is the most effective way to control and maintain a constant 65-75 F intake temp? |
09-17-2013, 06:08 PM | #1867 |
Drives: 2013 Scion FR-S, Nissan Pathfinder
Million dollar question indeed lol
Sent from my SGH-I337M using Tapatalk 4 |
09-17-2013, 06:24 PM | #1868 |
That Guy
Drives: 2013 asphalt FRS MT
There's a difference between a fan and a compressor. A fan isn't capable of creating a pressure ratio.
The Following User Says Thank You to Calum For This Useful Post: | DAEMANO (09-17-2013) |
09-17-2013, 06:46 PM | #1869 |
Drives: stock
Have an ESC thermister feedback loop control a 12v servo mixing damper (butterfly valve) with separate intakes (y pipe) one drawing cold bumper air and one drawing warm air near exhaust manifold.
09-17-2013, 07:50 PM | #1870 | |
That thing must feel like a blast now. Sent from my HTC One using Tapatalk 4 |
09-17-2013, 08:09 PM | #1871 | |
Drives: DGM BRZ limited
09-17-2013, 08:14 PM | #1872 |
Drives: FR-S 10 #103 AT
Or just spend the money on a hyper efficient water/air intercooler.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
09-17-2013, 08:34 PM | #1873 |
Atoning Unifex
Drives: '13 BRZ Premium, WR Blue
At 11 PM last weekend, Torque measured an intake temperature of a cool 114 F. Lowest I've run so far.
09-17-2013, 08:49 PM | #1874 |
09-17-2013, 08:53 PM | #1876 |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
