09-16-2013, 03:39 PM | #1835 | |
Max boost at 0 RPM is 5psi Max boost at 7500 RPM is ~2psi If you try and stuff 5psi into a engine at 0-1500 rpm it isnt going to be that happy. Then engine isnt very efficient at that range and focing air into it during that time doesn't net you anything except increase load on everything. If you do go WOT at that low rpm, i have once, the car just kinda bogs and isnt happy. At the same time it goes very rich because it doesnt really know whats going on. ThaTruths drift office tune starts as low as ~1800rpm(i heard) and it was happy, however; just remember the load your are putting on your poor engine |
The Following User Says Thank You to fenton For This Useful Post: | DAEMANO (09-16-2013) |
09-16-2013, 03:40 PM | #1836 |
Thats great to hear. I just feel so bad going WOT that low lol.
09-16-2013, 03:42 PM | #1837 |
Drives: Raven FR-S
09-16-2013, 05:42 PM | #1838 |
Drives: WR Blue BRZ, 240Z
My kit arrived today. My batteries should arrive tomorrow. I will be driving an ESC boosted -86 on Wednesday. I need to get with @moto-mike shortly thereafter to have the BRZEdit tune flashed or possibly a custom tune. Don't know about the tune details yet.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
The Following User Says Thank You to Gary in NJ For This Useful Post: | raven1231 (09-16-2013) |
09-16-2013, 06:02 PM | #1839 |
DEEEERP
i went to their website and didnt see anything. where can i get one of these and how much are they?
09-16-2013, 06:04 PM | #1840 | |
Drives: VW
Build a connector/box/circuit MAP Vclamp as per PUG's diagram (values not tested yet). Buy /splice/wire/calibrate an adjustable rpm window switch. or BRZlite/Tantrix/Toma file. Either one has costs, one gives you more, one gives you less. or Run stock tune/CEL/ mindful boosting below ~3K. |
The Following User Says Thank You to Robftss For This Useful Post: | raven1231 (09-16-2013) |
09-16-2013, 06:13 PM | #1841 |
09-16-2013, 06:42 PM | #1843 | |
DEEEERP
im sorry guys, i couldve sworn i read someone actually ordered one. thanks for the heads up
09-16-2013, 07:13 PM | #1844 |
09-16-2013, 07:34 PM | #1845 | |
Drives: FR-S 10 #103 AT
get @Robftss to cough up an explanation on how the controller works so we can build our own rpm sensitive circuit to provide partial boost starting at 1500 rpm building to full on at about 3250 when the pedal is to the metal.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
09-16-2013, 07:40 PM | #1846 | |
Drives: Raven FR-S
Knowing how long it took Rob to R&D this unit I have a feeling there will be many knock offs around the corner. Concerning modulation of the unit's output, I can send you about 20 emails debating it with Rob. At the end of the day is it achievable, yes but it becomes more complicated which leads to driving up costs. We all want the bells and whistles, but the cost of the feature might become a turn off. Personally, I thnk Toyota should write Rob a fat ass check and incorporate the unit into an hybrid version of the car. Last edited by Thatruth2001; 09-16-2013 at 07:56 PM. |
The Following User Says Thank You to Thatruth2001 For This Useful Post: | raven1231 (09-16-2013) |
09-16-2013, 08:00 PM | #1847 |
Drives: They have four wheels
Good luck w/ that. I'd rather drive a Geely, that way death will be quick and relatively painless.
The Following User Says Thank You to Anaxilus For This Useful Post: | raven1231 (09-16-2013) |
09-16-2013, 08:27 PM | #1848 | |
Atoning Unifex
Drives: '13 BRZ Premium, WR Blue
The way I was originally planning to try was to add a Bluetooth module to my advanced monitor and use that to poll the RPM every 0.5 seconds (practical max) to decide to enable/disable/modulate the throttle switch, however my ELM327 bluetooth ODBII connector can't handle two masters, so that would mean Torque doesn't work. For this reason, I haven't bothered to build that in. A more complex way is to tap the sensor lines leading to the ECU, like here: http://www.arduinoos.com/2013/08/engine-rpm-part-1/, but that's beyond my comfort level; it'd need a separate Arduino microcontroller just to handle that sensor, and then report back to the "main" microcontroller. I'm afraid I'm not an EE, just a poor dirty mathematician and computer scientist; I'm having all manner of fun screwing up my monitor circuit each weekend and it isn't working yet |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
