Software Tuning Discuss all software tuning topics. |
10-14-2021, 05:20 AM | #85 | |
Drives: 86 GT
@Kodename47 coming back to this again...
For the WOT Best VVT calculation this was mentioned in the wiki: Quote:
Thing is none of the current Tactrix log files are able to log the commanded AVCS, you could use OBD2 PIDs but the capture speed probably isn't enough. I did a comparison, feeding actual and commanded values (created a new column to to put table values where RPM and load is concerned) and there isn't a major difference; mostly the same on midrange but +5/-5 degs away at redline. |
10-15-2021, 03:44 AM | #86 |
Drives: 86 GT
Did a few runs on the exhaust AVCS with a -8, -4, 0, +4 and +8 and fed the results back to the tune. Naturally the optimum angles were peaky and wavy so I attempted to smooth out between peaks, with the system tracking rather well.
Despite running with -1 timing and without LTFT (my LTFTs are typically 2-3%) my typical knock at 5k RPM and at redline was eliminated so it looks like a good start. https://datazap.me/u/compelica/vvt-i...zoom=4746-4876 For testing purposes I then loaded the unsmoothened exhaust angles as per VGI results and while the AVCS system could still track targets I would start to get knock at the rapid dips of the exhaust VVT movement. This was running at full KCA though. https://datazap.me/u/compelica/intak...zoom=3448-3872 |
10-15-2021, 10:26 AM | #87 |
Drives: Subaru BRZ 2016
In the above logs the engine load varies very smoothly compared to the MAF voltage, especially at low RPM and wide open throttle. With what device do you log? Or did you manually filter the engine load?
10-15-2021, 11:04 AM | #88 |
Drives: 86 GT
Similar Threads | ||||
AVCS tuning | Turdinator | Software Tuning | 9 | 11-24-2015 01:31 PM |
AVCS tuning for power and economy | KoolBRZ | Software Tuning | 8 | 04-13-2015 11:07 AM |
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning | sw20kosh | Northern California | 27 | 11-28-2014 07:53 PM |
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
Dyno Nights @ FR&R tuning | GeeTee86 | AFRICA | 1 | 06-25-2013 04:25 AM |
