Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
06-20-2019, 11:29 PM | #15 |
義理チョコ
Damn! I failed to anticipate that answer.
05-25-2020, 12:46 AM | #17 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
05-26-2020, 01:14 AM | #18 |
Drives: MR2, Sliver BRZ
Imposible, its hard coded to the cluster itself independent of ECU or ABS unit. plus it has nothing to do with the ECU.
Always looking to tinker with something..
05-26-2020, 01:16 AM | #19 | |
Older ECM? what do you mean?
05-26-2020, 03:19 PM | #20 |
2013 A01C calibration computer vs. whatever the +2017 calibrations. Changes in sensor pin locations etc. etc.
Intent > Content
05-28-2020, 03:19 AM | #21 | |
Gerald R.
05-28-2020, 05:03 AM | #22 | |
Intent > Content
05-28-2020, 08:17 AM | #23 | |
05-28-2020, 12:37 PM | #24 |
Yeah thats what i mean in regards of canbus. Same signals used. Their is no difference in the data between a FRS or BRZ or GT86 pre 17 or post 17. The only difference between models (which is small) is between a push button or turn key. But in regards to what the original question asked its not possible to keep on the gauge in any way. not even a ECU or ABS flash nothing. As this is hard coded to the cluster itself.
The Following User Says Thank You to geraldjust For This Useful Post: | Tcoat (05-28-2020) |
05-31-2020, 11:33 PM | #25 | |
06-01-2020, 03:47 AM | #26 |
no unless you know programming, reverse engineer the custom chip they use. etc etc... i have dumped both flash info from the cluster but i did not see anything about the g-meter. sorry.
The Following User Says Thank You to geraldjust For This Useful Post: | Ultramaroon (06-01-2020) |
06-01-2020, 07:47 PM | #27 | |
Did you ever try modifying the dumped flash for example changing graphics around if there are any raw bitmap graphics in there? |
Similar Threads | ||||
2017 G meter | imprezza | BRZ First-Gen (2012+) -- General Topics | 103 | 10-27-2020 10:23 PM |
LHD 3-meter gauge-pod? | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 02-11-2015 06:19 PM |
TRD Sports Meter Kit | imravenit | Electronics | Audio | NAV | Infotainment | 18 | 05-10-2013 10:06 AM |
G-force meter | mikepaul21 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-17-2013 02:24 PM |
Does it have MPG meter? | 8987846 | BRZ First-Gen (2012+) -- General Topics | 34 | 05-18-2012 01:35 AM |
