Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-22-2024, 09:55 PM | #1 |
Drives: 2018 BRZ
Whiteline KCA434 can reduce anti-dive?
I'm swapping my front control arm bushings for Whiteline KCA434 and W0509. I was talking to a friend and he suggested that it should be possible to change the anti-dive geometry by stacking the two outer bushings together at the top of the control arm, similarly to the Jackson Racing Anti-Dive Kit. This should achieve a similar effect of lowering the position of the control arm.
Has anyone tried something like that? I sent an email to Whiteline as well with this question and will report back with their response. |
03-23-2024, 06:53 PM | #2 |
Drives: Crapcan
Might have too much deflection.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ohio Enthusiast (03-23-2024) |
03-23-2024, 06:55 PM | #3 |
Drives: Crapcan
Also not sure how much the mounting bolt would like having the sheer load put on it like that with having two bushings there.
03-23-2024, 08:52 PM | #4 |
Drives: 2018 BRZ
Good points. I probably won't attempt it if no one else had any experience and Whiteline either don't respond or respond that they do not recommend it.
The only silver lining is that trying it out won't involve pressing the big metal part of the bushings (which is a huge pain), and can be done without removing the control arm from the knuckle (just from the car). |
03-30-2024, 08:25 AM | #5 |
Drives: 2018 BRZ
Whiteline did not respond, but I think it would be a bad idea. When installed on the car and in full droop the two outside bushings are the ones allowing the control arm to pivot. Without them I'm not sure how well the arm will move (if at all). The top bushing is squished in the opposite direction, so both would be needed, IMO.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | NoHaveMSG (03-30-2024) |
Similar Threads | ||||
Whiteline Diff outrigger, Superpro full subframe and front LCA anti-divebushings | in_sherman | Brakes, Suspension, Chassis | 2 | 08-24-2020 03:35 PM |
Tanabe Strut Bar / Eibach Anti Sway Bars/ Whiteline endlinks / Avo under body brace | andy86 | Brakes, Suspension, Chassis | 7 | 10-24-2017 11:06 AM |
DIY: Whiteline Anti Lift Kit Install | RallySport Direct | DIY (Do-It-Yourself) Guides | 7 | 03-13-2015 07:37 PM |
Need some help with KCA434 | SubaSteve | Mid-Atlantic | 0 | 04-03-2014 08:18 PM |
Sheared my Whiteline anti-lift kit bushing! | Tye300 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 01-04-2014 06:14 PM |
