Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-11-2020, 01:08 PM | #1 |
Drives: 2017 Toyota 86
Oil Drain Plug in the O2 hole?
My FlexFuel sensor already replaces the rear O2 Sensor from the stock Exhaust manifold. I'm installing headers now and don't really see the point in installing the O2 sensor back into the rear hole. (hehe) I found an oil drain plug that fits. Will that seal with a copper washer and take the heat ok long term?
08-11-2020, 01:24 PM | #2 |
Rust bucket enthusiast
It'll be just fine
The Following User Says Thank You to DarkPira7e For This Useful Post: | pallen (08-11-2020) |
08-11-2020, 07:25 PM | #3 |
Or you could put wide-band sensor in.
The Following User Says Thank You to Grady For This Useful Post: | DarkPira7e (08-11-2020) |
08-12-2020, 10:11 AM | #4 |
08-12-2020, 10:57 AM | #5 |
The Dictater
Drives: '13 Red Scion FRS
Wait, so the first sensor hole in the header has your primary O2 sensor in it, and the second hole has a flex fuel sensor in it? What other hole are you looking to plug?
08-12-2020, 12:49 PM | #6 | |
Drives: 22 BRZ limited
No. The electrical plug for the secondary O2 sensor has the flex fuel kit plugged into it. They removed the now unused sensor from the header, and plugged the hole. |
The Following User Says Thank You to dragoontwo For This Useful Post: | Spuds (08-12-2020) |
08-12-2020, 12:53 PM | #7 |
Right, the rear O2 sensor was still in the header, but disconnected. The Delicious Tuning FlexFuel thing was plugged into the electrical port where the O2 sensor would have been plugged in.
The Following User Says Thank You to pallen For This Useful Post: | Spuds (08-12-2020) |
08-12-2020, 01:46 PM | #8 | ||
The Dictater
As for the second hole, I would just plug it with the extra sensor OP has instead of taking the chance on something that probably fits and seals, but we aren't sure how it responds to exhaust levels of heat. But that's just me. |
The Following User Says Thank You to Spuds For This Useful Post: | dragoontwo (08-12-2020) |
08-12-2020, 02:02 PM | #9 | |
Some headers come with plugs installed in the holes and leave it up to the end user to figure out where you want the sensor, or if you want to run one at all. You can pick up plugs with copper washers on Amazon for about $6. |
08-12-2020, 02:57 PM | #10 |
If anyone needs the info, this is the one I got - had to add a matching copper washer because this comes with a rubber one.
https://www.oreillyauto.com/detail/b...090167/4177507 I decided against leaving the existing O2 sensor in for a few reasons. 1. I didn't want a disconnected O2 sensor wire floating around inviting questions at inspection time or just looking messy. 2. I didn't want the sensor sitting there getting hot and possibly failing in case I ever decide to go back to stock. I screwed it back into the stock manifold for safe keeping. 3. I like things to be clean and smooth - extra sensors poking out could only make installation more difficult |
08-12-2020, 03:05 PM | #11 |
The Following User Says Thank You to Grady For This Useful Post: | pallen (08-12-2020) |
08-12-2020, 03:07 PM | #12 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
How long is the oil bolt?
Will it protrude into the exhaust path and slow your roll?
"I gotta rock." -- Charley Brown |
08-12-2020, 04:27 PM | #13 | |
This isn't mine, but it looks just like mine - you can see the holes for the O2 sensors. |
08-13-2020, 12:55 PM | #14 | |
The Following User Says Thank You to Grady For This Useful Post: | pallen (08-13-2020) |
Similar Threads | ||||
drain hole oil filter housing? | sneaky_pete | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 02-06-2020 04:21 PM |
Need help extracting drain plug... | SamtheKorean | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 33 | 01-25-2020 05:18 PM |
Am I missing a plug for this hole (photo)? | trvth | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 08-08-2017 04:49 PM |
Drain plug leaking...what to do... | OUGrad05 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 03-28-2016 02:01 PM |
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
