02-23-2016, 03:51 AM | #925 |
Drives: JAWS
Thanks. I suppose relying on 02 sensor/knock sensor readings is the best we can do for self-adjusting tunes without getting too crazy.
02-23-2016, 06:47 AM | #926 |
Drives: UK GT86
Having an idea of what the cams are doing WRT overlap in a pull will prove out any "lean" spots. You want a smooth MAF curve, if it's lumpy then it's likely that you're compensating for added O2 due to overlap and not a leaner mixture.
.: Stealth 86 :.
02-23-2016, 09:10 PM | #927 |
Drives: JAWS
Okay that makes perfect sense. I just have no idea how to analyze cam overlap
02-24-2016, 02:27 AM | #928 | |
Drives: UK GT86
Code:
=-9+(Ex Retard)-(14-(In Advance))
.: Stealth 86 :.
02-24-2016, 03:01 AM | #929 |
Drives: JAWS
Where do I add that code? Sorry, new guy here
02-24-2016, 03:11 AM | #930 |
Drives: UK GT86
Into the datalog. Add a new header "AVCS Overlap" and then copy that formula down the column. Obviously replace the Intake and Exhaust references with the cells for the relevant cams.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | JB86'd (02-24-2016) |
02-25-2016, 10:46 AM | #931 | |
Drives: Toyota GT86 6M/T
Now this morning I had a chance to make on 3rd gear run which showed no knock, but before and after that, driving through the city just accelerating a bit but still in closed loop, it would show FLKC and FBKC often up to -1.3 . After the 3rd gear run IAM dropped to 0.88. Later when IAM was at 0.91 I got to do a 2nd gear run, which also seemed to knock quite much. Looks like the car is now running mostly lean. Annoying if the VGI tool has over-corrected the MAF scale. Do you think that is the case? Or might it be due to load limits? Am I correct in assuming that logging and correcting MAF scale while IAM is below 1 is not very good..? 3rd gear run 2nd gear run |
02-25-2016, 02:14 PM | #932 | |
Drives: FT86
If you only altered the OL maf scaling it should not effect the you when driving "carefully" as your likely in closed loop. looks like the knock is in 2000-3000 area Did you fuel up at different station, might just be bad fuel ? |
02-25-2016, 06:14 PM | #933 | |
I also had this knock around 2000-3000rpm before I changed the MAF, but now it just knocks a lot more and does it also when cruising steadily at 3000-3500rpm and then accelerating with 15-20% throttle still in CL. May be bad fuel that has made the knock even worse as I filled up yesterday even though it was Shell V-Power as usual, but just another station that I normally don't use. But if it was bad fuel, that couldn't be a reason for the car now running lean especially around 3500-4000rpm, could it? |
02-26-2016, 01:40 AM | #934 | |
Drives: FT86
if the load limits are too low in that area it can cause lean area |
02-26-2016, 03:26 AM | #935 |
Drives: UK GT86
What CL > OL timers are you running? General consensus is that reducing or making them 0 usually makes a difference with issues like this. Seems that if it holds the CL fueling too much you can get this issue.
.: Stealth 86 :.
02-26-2016, 05:00 AM | #936 | ||
I haven't read about anyone modding those. Is there a thread about this? But then again, it knocks when going on the accelerator more than average but not so much that it switches to OL. I'll see if I can log some city driving, where the knock will be visible. Generally though it looks like actual engine load is often higher than the limits in the tables - especially when going on the throttle, which gives a load spike. |
02-26-2016, 05:32 AM | #937 | |
Drives: FT86
you might find that those load limits make your car run lean. When you log load im pretty sure its logging absolute load. but if it goes over the load limit you set it forces the ecu to look up the fueling and timing ect for the load specified in the load limit not the absolute load at that rpm If you look at the OL fueling table and timing limiting the load will stop the ecu using very rich fueling and retarted timing at low rpm when you get on the throttle in higher gear. this stops it bogging down. If you get to agressive with the load limits at lower rpm the ecu will look up the load limited values causing it to run leaner with more timing than it would if the load limit did not exist. Hence you may need to run a more linear load limit table in your case. Last edited by steve99; 02-26-2016 at 05:50 AM. |
02-26-2016, 11:09 AM | #938 | |
But why are there any load limits at all? Isn't it best, if the load limits aren't reached at any point? With "more linear" do you mean that the load limit should reach 1.3/1.4 at lower rpm and then remain there for the top range? I tried to mod the load limits again so that WOT from 2500rpm shouldn't exceed the limit anymore. Do you think the table looks acceptable? I made another 5th gear pull earlier which has a lot of knock and IAM lowered to 0.98, and a short 4th gear pull from 4000rpm. Car ran lean all the way as you can see. Hope the revised load limits help. 4th gear pull 5th gear pull |
Similar Threads | ||||
RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
