Old 04-23-2021, 01:04 PM   #1
lucas86
Drives: 17' steel 86
Can i swap my 86 key to an FRS key?
Is it possible to swap my toyota 86 key for a scion fr-s key. Personally a much bigger fan of the FRS key.
lucas86 is offline   Reply With Quote
Old 04-23-2021, 01:09 PM   #2
No. Or more accurately not without paying a pile of money. They keys are chipped for the car and there is no easy way to recode them.
Old 04-23-2021, 01:09 PM   #3
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
a little confused..if you have an 86 key without push button start, isn't the difference between that and pre-facelift FRS key just the Toyota vs Scion logo..? if so, I'm pretty sure they are the same exact model and you can just replace the cover with the logo..
HKz is offline   Reply With Quote
Old 04-23-2021, 01:15 PM   #4
Post 2017
Pre 17
Not a big enough difference to worry about but to each their own I guess.
Old 04-23-2021, 01:55 PM   #5
HKz
Reformed
HKz's Avatar
Post 2017
Pre 17
Hmm but my current '16 and I could've sworn the '13 i had also came with the same key that you're saying is for the facelifted model except with the scion badge..and I've driven a couple facelifted 86 without the push button start and i thought they had the same key too.
My key..
The Following 2 Users Say Thank You to HKz For This Useful Post:
KR-S (04-23-2021), Tcoat (04-23-2021)
Old 04-23-2021, 02:14 PM   #6
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
My key..
I also have the same exact key for my 2015 frs.
Correct me if I am wrong but I believe it is "Post '15"?
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following 2 Users Say Thank You to KMA KiCKz For This Useful Post:
HKz (04-23-2021), Tcoat (04-23-2021)
Old 04-23-2021, 02:18 PM   #7
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Post 2017
Actually we got the redesigned key sometime before 2017. Can confirm; I have the same exact key in the picture there, just without the Toyota logo.
This design might have debuted in 2015; my aunt's previous 2015 Camry used the exact same key fob. I can also confirm that the backs are completely interchangeable too (test fit her key cover with my key and it fit). If OP is just looking to replace the key cover, I assume he's going to need the VIN of a Scion made after 2015 (at least that's my experience when trying to acquire a Toyota key cover to replace my worn Scion one, may not be for every dealer though).
Originally Posted by klearfade View Post
Is that gel in your hair?!
Originally Posted by HueyLooie View Post
Nah, homes. It's your dadda's hot goopey goop.
The Following 2 Users Say Thank You to KR-S For This Useful Post:
Old 04-23-2021, 02:34 PM   #8
My key..
Yep I had no idea when they actually changed it but was answering more based on the original question.
What is this "key" you all speak of anyway?
FOB crowd uber alles!
HKz (04-23-2021), Jdmjunkie (04-23-2021), KR-S (04-23-2021), spike021 (04-23-2021)
Old 04-23-2021, 02:38 PM   #9
HKz
Reformed
HKz's Avatar
manual car, manual key noob
Old 04-23-2021, 02:40 PM   #10
More engaged in unlocking the door. Only a true door unlocking enthusiast will understand.
The Following 7 Users Say Thank You to Tcoat For This Useful Post:
alphasaur (04-23-2021), Dadhawk (04-23-2021), HKz (04-23-2021), Jdmjunkie (04-23-2021), KR-S (04-23-2021), MuseChaser (04-23-2021), spike021 (04-23-2021)
Old 04-23-2021, 03:32 PM   #11
Sasquachulator
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
Switch it with the Scion IM's chunky switchblade key!
The Following 2 Users Say Thank You to Sasquachulator For This Useful Post:
dnieves (04-23-2021), spike021 (04-23-2021)
Old 04-23-2021, 04:29 PM   #12
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
It is even better if you use the no-remote, all-analog key. Pure auto-erotica.
PetrolioBenzina is offline   Reply With Quote
The Following 2 Users Say Thank You to PetrolioBenzina For This Useful Post:
alphasaur (04-23-2021), Tcoat (04-23-2021)
Old 04-23-2021, 05:35 PM   #13
Well there is a lot you can do while digging through your pocket for it.
Old 04-23-2021, 06:06 PM   #14
pope
has a funny hat
Drives: 2014 BRZ Limited
Why not both? Look down on the plebeians and enjoy the physical purity of manual actuation.
This is my keychain. I added a keyed steering lock so I can move the car around my garage without a battery in the car. Extra side benefit, FOB cloning car thieves won't get very far without steering. (A surprisingly valid concern for the size of Kalamazoo metro area (at least if vehicle theft reports on the community discussions apps are accurate)).
pope is offline   Reply With Quote
86 key, frs key, key fob
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
Key Fob Swap joergasm BRZ First-Gen (2012+) -- General Topics 1 10-02-2012 11:40 PM
