Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 04-19-2022, 09:51 AM   #15
Petah78
Drives: 2022 BRZ sport-tech
Looks promising in terms of pressure, unlike the previous gen where it lost significant pressure with heat.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
The Following User Says Thank You to Petah78 For This Useful Post:
KillerBMotorsport (04-20-2022)
Old 04-19-2022, 10:56 AM   #16
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Except in the data provided here, there is no significant heat. Though it looks good, this more or less matches gen1's data so far at low oil temps.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
Tokay444 (04-20-2022)
Old 04-19-2022, 11:03 AM   #17
Petah78
He did say the dash read 10-15 higher meaning it would have indicated about 245-250 on the dash? That is already pretty high. Most guys that track their gen1 were seeing about 270 without oil cooler.
Old 04-19-2022, 04:41 PM   #18
BRZ FTW
Drives: 2017 Subaru BRZ
Originally Posted by Stonehorsw View Post
I can’t see any picture you post
same. had to use Firefox on Mac
BRZ FTW is offline   Reply With Quote
Old 04-19-2022, 05:03 PM   #19
KillerBMotorsport
KillerBMotorsport's Avatar
Max temp was 205° in the sump and it kept getting cooler after each pull. The opposite of what is typical, but it was a cooler day and we do have 30hp worth of wind tunnel blowers.
I'll likely plug in the oil temp/pressure during another test this summer when it's hot and humid. That that doesn't bring higher temps, I'd cut out a few of the blowers.
I think you're looking at the pressure lines. The temp lines are pinkish. So 205° is going to read ~220° on the dash.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
Dzmitry (04-21-2022), Petah78 (04-19-2022)
Old 04-19-2022, 08:06 PM   #20
Petah78
My bad, thanks for correcting me.
The Following 2 Users Say Thank You to Petah78 For This Useful Post:
Dzmitry (04-21-2022), KillerBMotorsport (04-20-2022)
Old 04-20-2022, 07:18 AM   #21
KillerBMotorsport
Originally Posted by alphasaur View Post
Strong numbers for a mustang dyno.
I was very surprised. Especially where comparing to the modded and tuned previous gen. Our dyno reads low, even compared to other Mustangs, so my assumption going in was ~180 peak HP. Pleasantly surprised.
I should also note this car does have our dual AOS setup installed, but that should not be contributing to power in any appreciable amount, especially at 1,400 miles on the clock.
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
alphasaur (05-11-2022)
Old 04-20-2022, 01:41 PM   #22
OkieSnuffBox
Drives: '23 BRZ Limited
245-250 is not high. Hell the oil temp thermostat on my 135i didn't even open until 240 and that was from the factory.
Modern vehicles with synthetic don't go into "limp mode" until the oil hits north of 300.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Danny318 (04-21-2022)
Old 04-20-2022, 02:25 PM   #23
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That motor was designed to run at 250 degrees nominally, not 200 like this one. Clearances and tolerances would be adjusted accordingly.
Old 04-20-2022, 04:05 PM   #24
Ohio Enthusiast
Drives: 2018 BRZ
How do you know the FA24 (or the FA20 before it) was designed to run at 200?
Ohio Enthusiast is online now   Reply With Quote
Old 04-20-2022, 04:28 PM   #25
Tokay444
Anti stance.
Tokay444's Avatar
Why do we care more about oil temp in the sump, vs inside the motor where it's actually working?
Old 04-20-2022, 07:43 PM   #26
OkieSnuffBox
Where did you come up with this?
All modern engines are designed to run much hotter than engines from years past. They are more efficient and produce less emissions.
Old 04-20-2022, 10:21 PM   #27
KillerBMotorsport
The SOP for track applications is to always know the temp of the oil going into the engine.
Old 04-21-2022, 08:28 AM   #28
Tokay444
Anti stance.
Tokay444's Avatar
Ok, but why? Or is it a matter of, "This is how it's always been done" dogma?
Search this Thread:
Advanced Search
High Flow Oil Pickup by Killer B Motorsport KillerBMotorsport Engine, Exhaust, Bolt-Ons 4 04-26-2022 10:51 AM
If you post a dyno plot, please, include what the fuel was used. Calum Forced Induction 1 10-12-2015 07:59 PM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 07:09 PM
