Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-07-2018, 10:58 PM | #15 | |
The Dictater
Drives: '13 Red Scion FRS
If that's what the logged readings are actually averaging to, you should be fine to do nothing about it for normal driving, though your AFR in the upper rev range might be a bit off. Solution is to rescale the maf. The scale for that intake might be posted somewhere, or you can do it the long way. Or maybe the manufacturer has it available. |
05-07-2018, 11:02 PM | #16 |
Drives: BRZ 2017
THANK you so much! Would i be fine running e85 on the current ltft as well?
05-07-2018, 11:17 PM | #17 |
The Dictater
Well if you do, your ltft will change quite a bit at the least. Other than that . If it were my car, I'd run a tune. There's a post on here where that was discussed by folks with much more experience than me. I'd suggest finding that.
The Following User Says Thank You to Spuds For This Useful Post: | Sel_brz17 (05-08-2018) |
Similar Threads | ||||
Diagnosing high positive LTFT | Tectoniic | Software Tuning | 22 | 05-03-2022 02:24 AM |
strange LTFT | bee_are_zee | Software Tuning | 11 | 05-17-2016 07:28 PM |
LTFT reading oft | mike7792 | Software Tuning | 1 | 02-01-2016 09:21 PM |
Where are LTFT data stored? | RustySocket | Software Tuning | 7 | 10-04-2015 10:01 AM |
high ltft at idle, my how to fix it(not fixed yet) | trdric | Software Tuning | 16 | 06-18-2015 10:27 PM |
