Software Tuning Discuss all software tuning topics. |
04-10-2018, 04:02 AM | #29 |
Drives: silver brz 2013 lmtd
Sorry, the raspyness is just the tip of the iceberg that overall set it off for me. I didn't write a thorough comment. There is high knock, IAM has dropped to .56, AFR is not hitting targets it should be... full WOT is like 13:1 instead of 11-12:1, I thought the basemap wouldn't need so much change and tweaking, but it seems it does. What front pipe do you recommend?
05-17-2018, 10:21 PM | #30 | |
Drives: Hyper Blue BRZ
why not just copy the VVT tables from OTS 2.076 tune which had EL specific maps
05-23-2018, 12:57 PM | #31 |
Can these tables be used on a CATTED JDL UEL ?
05-23-2018, 02:39 PM | #32 |
Drives: brz 2017 hksv2
i wouldn t use that for EL map... use the one for EL in v2 tunes..they are better for EL for the dip
05-23-2018, 07:58 PM | #33 |
Drives: FT86
05-23-2018, 09:29 PM | #34 |
I meant the VVT tables shiv posted earlier in the post?
so i tried these JDL specific VVTs and i get quiet a drone at 2800 - 3000 RPM. I tried the VVTs from V4.0 and the car was a lot more toned down, so this 4.0 UEL tables are based on catted http://www.ft86speedfactory.com/ft-8...l#.WwYS9GgvxD8 which are actually a bit different from the JDL, the JDL have longer runners http://www.ft86speedfactory.com/jdl-...l#.WwYTwmgvxD8 thanks @steve99 |
06-18-2018, 04:51 PM | #36 |
Drives: 2017 Halo 86
Does anyone else have issues with trying to install RomRaider? Getting a blank page after clicking the Next button on the page that shows you'll be installing the Base and Source Files, along with space required. Ran in Admin privileges, no antivirus running, Windows. Re-downloaded again, same thing. Weird.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
09-19-2018, 12:26 PM | #37 |
Drives: 2017 WRB BRZ Limited PP
Do these JDL UEL cam timing values still apply for the 2017+ BRZ? Im currently using the stage 2+ V4.02 tune and the timing values are still noticeably different from the ones Shiv posted here.
10-07-2018, 10:15 AM | #38 |
Drives: whiteout fr-s
Hey im wondering if i can upgrade to the latest version of oft for my frs. and still be able to use these values given by shiv for 93 octane uel catless jdl header.... 2013 frs btw. ?? Will it work? Shiv@openflash
Similar Threads | ||||
frs headers | vitopell | Engine, Exhaust, Transmission | 6 | 07-10-2014 06:44 PM |
LOOKING FOR OEM HEADERS | cj1pilot246 | Northern California | 0 | 01-21-2014 08:54 PM |
Injen SES Headers/ Agency Power headers | Choong86 | Engine, Exhaust, Transmission | 10 | 12-27-2013 09:51 PM |
UEL headers | pepe | Engine, Exhaust, Transmission | 43 | 11-12-2013 10:40 PM |
Headers | tdoggy57 | Engine, Exhaust, Transmission | 10 | 01-13-2013 05:09 AM |
